Rob,
My 4KW Onan didn't run when I got it. No fuel. I cleaned the fuel system.
Then too much fuel, bad needle & seat, parts missing. Then it ran, only it
died when I kicked on the overhead A/C. New points, that was a challenge.
Runs great. Looks like the job's finished. Give it the first bath of its
life. Then no power. It was only making 5V AC, not 115V AC. Cleaned dirty
commutator, repaired sticking brushes & broken or loose terminals. Ohmed out
breaker and everything else. Found bad (shorted) rectifier bridge. That's
where the $8 came in. Finally I used a frequency (Fluke 78) meter to dial in
the RPM to 60 Hz. I have a hard time believing that washing it would wipe
out the rectifier, but it did. I still let it warm up before hitting it with
the big load, but now "momma" can fire it up from inside the coach. When
she's happy and we're happy. BTW I used the NET for a lot of advise on what
to do. You'll have to choose what's wrong & what's right for your situation.
> -----Original Message-----
> From: owner-gmcmotorhome
> [mailto
wner-gmcmotorhome]On Behalf Of robteed
> Sent: Thursday, September 03, 1998 6:20 PM
> To: gmcmotorhome
> Subject: RE: GMC: Re:Onan Gen
> Hi Jim,
> No...I havent got access to a meter Yet. Come
> to think of it, One of My friends has one. Guess
> I'll have to borrow it. Are You saying that You
> washed the unit which caused the rectifier to go bad?
> Thanks, Rob Teed
> > [mailto
wner-gmcmotorhome]On Behalf Of Jim Green
> > Sent: Thursday, September 03, 1998 7:13 AM
> > To: gmcmotorhome
> > My rectifier was bad, after I washed the unit. Cost me $8. I also
> > cleaned my
> > commutator and brushes, they were sticking. I had a reading of
> 5V AC with
> > the bad rectifier. Have you used a meter on the system ?
> > > [mailto
> > > Sent: Wednesday, September 02, 1998 8:34 PM
> > > To: gmcmotorhome
> > > Yes, I checked that. Could it be the bridge rectifier?
> > > > [mailto
wner-gmcmotorhome]On Behalf Of Jim Davis
> > > > Sent: Wednesday, September 02, 1998 8:23 PM
> > > > To: gmcmotorhome
> > > > Subject: Re: GMC: Re:Onan Gen
> > > > Maybe even more simple than the simple stuff....Is the generator
> > > > plugged in
> > > > to the female plug in the water-electrical cord
> > cabinet?......Jim Davis
> > > > > From: Samuel Pickens
> > > > > To: gmcmotorhome
> > > > > Date: Tuesday, September 01, 1998 6:34 PM
> > > > > Simple stuff first. Shut down unit. Goto breaker; continuity
> > > to ground,
> > > > > Open? Yes, goto continuity through breaker. Yes? check w/
> J Bounds.
> > > > Sounds
> > > > > like a knowledgable guy to me.
> > > > > From: robteed
> > > > > To: Gmcmotorhome Org
> > > > > Date: Tuesday, September 01, 1998 9:22 PM
> > > > > Subject: Re:GMC: Onan Gen
> > > > > >Well, I finally got around to starting the
> > > > > > generator. ( 4000 watt Onan ). I replaced
> > > > > > the gas line, Hooked up the jumper cables.
> > > > > > Then hooked up the bypass jumper to turn
> > > > > > on the fuel pump. It started right up. Had
> > > > > > been sitting since 1987!!!! Sounds good. Only
> > > > > > now its not generating power. No 110 current
> > > > > > inside. Any Ideas????
> > > > > > Thanks,
> > > > > > Rob Teed
> > > > > >Also,
> > > > > > Whos in Okemos,Mi ????
> > > > > > I talked to You a few months ago...Computer
> > > > > > crashed. Lost Your Number. Im in Lansing
