I recently swapped my Onan. It starts and runs reliably— for a while. After a few minutes it starts to run rich and eventually dies. It will then refuse to start for a while.
Assuming it was slowly flooding, I disconnected the fuel pump's 12v supply and started it up. It struggled to start, but then started, and ran better and better and better until running out of gas. This reliably fixes the problem whenever it dies.
I adjusted the float to the specs in the manual. With this setting it flooded so badly that gas flowed out the intake. I set the float ridiculously high, hooked the fuel line back up and powered the pump. With the float in this position the bowl wouldn't fill at all.
I've adjusted the float a dozen times and I can't stop it from eventually flooding, or completely starving.
Is there a better way!?
The process is so painful — disassemble, adjust, reassemble, hook up fuel line, test, disassemble, adjust, reassemble, hook up the fuel line, test, etc
I've already rebuilt the carb, and I have another recently rebuilt carb. I've tried both seats. I'm using the fuel pump from Applied, so I assume its pressure specs are correct.
New carbs are like $30, making it VERY tempting to find a "generic" replacement. If someone knows a viable replacement I'd be very interested in the model that worked.
