Onan bridge rectifier failed again
richard guthart
293
Any ideas what could be causing bridge rectifier failure? After the O.E. one
failed a couple of weeks ago I replaced it with the 25 amp 1000 volt one
recommended here. (Actually it was the next beefier one by same mfg., rated 40
amps 1000 volts; nearby electronics store didn't have the other one.)
Anyway, The Onan ran perfectly for 2 hours, and again for one hour a day later
but now no AC output again. Pulled the bridge rectifier and it fails the
electrical checkout tests.
I was even careful to disconnect load before shutting down the Onan. I'm
wondering if I just got a bad rectifier or I have a more serious problem.
Richard
Lanier,
I plan to install the new part this afternoon and will let you know, probably
tomorrow.
Richard
> In a message dated 8/18/99 2:01:50 PM Central Daylight Time,
> Richard,
> Please keep us posted - I'm very interested in that problem. I haven't
> installed the 25/1000 yet, but figured I would before I get back on the
> road, but now I wonder if it's worth it?
> Lanier
I just replaced the bridge rectifier and now I have AC output from the Onan
again. I must have had a faulty part, as Duane suggested.
Richard
> Richard,
> Lanier
