Onan board connections
emerystora
14,608
1
1
I was working in my Onan and removed the wires from the board. I wasn’t too concerned because the small numbers inside the Molex connector would guide me.
The wires are marked with numbers for the terminals but my wires had darkened and discolored so I couldn’t read most of them. But inside the plug are very small numbers that correspond to the terminals.
I hooked the wires back up but I had a long one left that went to the number 4 terminal. There was a number four terminal at the top of the board that was bent over so it would not be used. This was a long wire so I knew that it went to the bottom of the board. I was left with one unused terminal between number nine and number eleven. But it was labeled with a 1 besides it. Where did the number four wire go?
I finally called Jim Miller and he checked a board in his shop and verified that the wire number 4 was plugged into the terminal Marked with a 1.
So if anyone has to figure out the connections by the little numbers inside the Molex plug they are all correct EXCEPT wire 4.
Emery Stora
77 Kingsley
Frederick CO
Emery,
I will send over all so you can Finger it out.
On Tue, Jul 21, 2020 at 1:13 PM Emery Stora via Gmclist <
> guide me.
> 1.
> Emery Stora
> 77 Kingsley
> Frederick CO
http://www.gmcrvparts.com
