Old Inventory
gene
2,215
The Boot.
Changing the oil, I found the passenger outside CV boot was torn. This is
the same one I had to re-band 3 times to get it to stop leaking. This boot
was changed last year during the front end up grade. In retrospect I think
it was old inventory at the time. There were no marks on the boot, it was
just faulty. It was a black boot but I think it was plastic.
Since I am leaving soon, for Or, I determined to install a split boot until
I get to Or. The first one I got was the wrong size , I found after I had
cut off the failed boot. The tear was too large to patch. I went to the
local parts store and was buying the split boot in a very yellow plastic
package ( obviously old inventory ) when I tried to straighten the boot out
to compare the size it literally crumbled in my hands. It split in about 4
places... the parts guy said they don't get much call for these.... What do
you think would have happened if I had hit the road with that piece of junk
on my drive line??
I inquired at my GMC dealer, and he had to order the boot --- "don't stock
old Toro stuff"....
No thanks, I ordered from Cinnabar over night UPS. They had the drive line
bolts also. No problem. Somehow I am sure their inventory is going to be
much fresher than my local GMC dealer.
I AM GLAD CINNABAR IS THERE !!!!
gene
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
yep could be you are correct
gene
>In a message dated 8/14/00 10:47:35 AM Eastern Daylight Time,
>Gene,
>Cinnabar reworked my chassis last year. I ended up with a bad boot that is
>puking grease from a defect on the parting line. Called Cinnabar and they
>said bring it in anytime and they will take care of it, which I am doing Wed.
>So paying the high dollar doesn't gaurantee anything, however the service is
>top notch.
>Dave 73
>GoBus 230
>To unsubscribe, e-mail: gmcmotorhome-unsubscribe
>For additional commands, e-mail: gmcmotorhome-help
mr.erf
