Ernest mentioned shelf life for gear lude. I buy my engine oil by the 55 gal barrel for my personal use. As I have it made up to my own specs. The manufacture of the barrel of oil. Told me that if the oil is kept at a constant temp, and sealed air tight. The oil will be fine for up to 6 years. As after that age. The additives that are added. Start to break down. And finally become the base stock that comes out of the ground. If gear lube additives age in the same way. This is something that needs to be looked into as to the useable life of gear lube additives. Bob Dunahugh
