Oil Seals
hemogoblin
138
Hi All,
There has been talk about the use of neoprene seals on the 455 engine to
replace the original rope seal. As far as I know the major advantage of the
neoprene over the rope is less drag ( read that as less power draw only in a
search for max HP), they are also easier and perhaps less intimidating than
the procedure for installing the rope. As I recall if the seal is to be
replaced in an assembled engine a tool resembling a chinese finger puzzle is
used to snake the seal around the upper half, additionally bearing caps must
be loosened, and ends must be carefully adjusted and cut.
Years ago I was building up a strong Pontiac 455, which used a rear rope
seal At that time a firm by the name of H&O Pontiac were the Gurus of great
running Ponchos, they sold a myriad of parts to improve the engines, they
also had a great Tech manual. One item they sold was a rear neoprene seal
designed like the Chevy . I installed that seal, mainly because it was state
of the art, modern as compared to the rope. Boy was I wrong, from the first
start (unfortunately after I installed the engine in my Trans Am ) it went
drip,drip, from the rear main. After work I pulled the engine, and removed
the neoprene seal, and replaced it with the rope type.A lot of work. I dont
know if the problem was crank surface, or the seal. Something to think
about!
Mark '77 Palm Beach LINY
