Oil Resrictors and high volume oil pumps
thomas g. warner
1,863
>From my archives:
Oiling:
HV oil pumps do pump more per/rpm than the standard volume oil pumps,
but what some forget is that the
pressure relief valve pops open at a set pressure, directing all the
excess oil back into the oil pan before it goes
up to the top of the block. Since the oil passages remain a constant
diameter, you are pumping exactly the
same amount of 55psi oil at 4000rpm using a HV pump as you are using a
standard pump; the pressure relief
valve is just allowing more of the HV's output to go back into the pan.
I suppose that in theory, the pressure relief might not be able to keep
up with the extra output of the HV pump,
but you would know this when you saw the oil pressure climbing at high
revs beyond what the pressure relief
valve spring is rated at (if you don't know what that is, you can
figure it out once you run your engine much
above idle, as a HV pump will "max out" rather quickly at a certain psi
and stay there no matter how much you
rev your engine- for example, my 403's HV pump hits 55psi by about
2000rpm and stays there, no matter
what I rev it to). In that case, you would need some reserve oil,
because the drainbacks in the heads would be
the bottleneck for the extra oil going through the lifters (which are
kind of "oil pumps" themselves).
As for the oil restrictors, they only restrict flow to the cam bearings
(refer to a diagram of the Olds V-8 oiling
system to confirm this one), not to the lifters or the pushrods or the
upper end of the engine. A reversible way
of achieving the same thing is to drill a smaller hole in your cam
bearings, and install that hole facing the oil
feed hole from the main journals. To restrict flow to the upper-end of
the engine, you need restricted
pushrods.
Now, the thing you might want to be concerned about is the oil foaming,
since the oil pressure relief valve is
just SPRAYING the oil back into the pan, and at a high rate at high
rpm's, you could have your oil pickup
sucking oil bubbles. Not good.
Consider this: you can have a high-capacity oil pan in a couple days
via mail-order for about $200, including
the extended pickup. How much have you already sunk into the motor? Is
it worth the extra peace of mind to
have a couple extra quarts of oil on hand to feed your engine? Then
again, unless you start running this engine
at a constant 4000rpm, you really won't encounter this problem. This is
your call.
>I'm wondering if perhaps the answer on restrictors is -if one has a
>Mondello oil pump, then maybe one needs to have the restrictors, as I
>think his pump puts out a lot more pressure than a stock one
>does.Someone mentioned a long time ago that at idle ,Joe M recomends
>35-45 lbs. pressure, whereas the GMC Maintance Manual says normal idle
>is 7psi and 1500-3000 RPM its 35PSI. Rather large differences in the
>figures, but maybe if one is racing that sort of pressure is needed I'd
>presume. Would it be reasonable to assume that with a stock pump one
>does not need restrictors, but with a Mondello one , one does require
>it? I don't know just asking?
>Claude in sunny Victoria.
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
"The beautiful Mohawk Vally"
