I recieved this reply to my inquiry about the correct
replacement for the oil pressure switch for the 6000
watt Onan on my GMC.
NAPA # OP6074 It replaces OE on several 80 ish GM
vehicles and a 90 ish
> Geo. Normally closed. Opens 3 - 8 psi (Byron
Maxwell)
> Borg Warner Oil Pressure Switch with a part number
S310 costs $5.00.
> (Richard Waters)
I work for Dana Corp which recently bought Echlin Inc.
Echlin makes parts for Napa and Borg Warner. I
contacted an engineer at our Kansas plant where the
oil pressure switches are made for both markets. His
response is below.
No problem although as stated below something is
questionable. NAPA model OP6074 does not equal BWD
S310, it does however equal BWD S510. Is this likely
just a typing error or is the S310 correct and the
NAPA OP6074 wrong.
If you want the O.P. from NAPA OP6074 our cost is 79
cents. Do you want 2?
I told him to get me the NAPA OP6074 if it does not
fit I will post later. I do appreciate the numbers
provided, my response is in the intrest of accuracy
only and for all I know both numbers fit the
application. Thanks all.
Do You Yahoo!?
Talk to your friends online with Yahoo! Messenger.
http://im.yahoo.com
Maxwell)
S310 costs $5.00.
> (Richard Waters)
response is below.
NAPA OP6074 wrong.
Do You Yahoo!?
http://im.yahoo.com
