Getting ready to do timing chain. Not sure how the front of the oil pan is
sealed when putting cover plate back on. Do I need a new
front oil pan gasket? Since the front motor mount is detached and the engine
can be raised, can the oil pan be removed or do you have to remove
the tranny and final drive according to the repair manual?
Also, the repair amnual picture of aligning the timing marks is really dark.
How do you make sure everything is lined up properly when putting a new
timing chain on?
Thanks
eric.henning
timing chain on?
Thanks
eric.henning
