>Are we sure it is
>an engine oil leak and not a transmission oil leak. Did you put a
>flourescent dye in one or the other (is that why you are using a
>flourescent light)?
>>Yes, the engine.
Well I'm still noodling then...
>On another subject, you mention a particular front and back stabilizer
>bar under enhancements you would not do without. It is a fairly
>impressive recommendation considering the reputation of all the other
>improvements in your must have list... Tell me more, when you have a
>minute.
>>The IPD stabilizers were installed mainly to pick up the backend as it
>>was real easy to scrape bumper coming out of gas stations etc. It also
>>resulted in better overall stability with reference to Interstate ruts.
>>Of course they've been on for so long, I can't remember how the ride
>>was before
>>It might be an idea to ask on the net if someone installed recently
>>enough to remember a before and after before spending the money.
>>Cheers Heinz
Anyone else have comments on stabilizers?
Regards,
John Dolan
jdolan
>flourescent light)?
>>Yes, the engine.
>minute.
>>was before
>>Cheers Heinz
Regards,
John Dolan
jdolan
