Well thank you for all the help. Wiped everything down and changed oil
and filter after the trip. I tightend down the valve covers to specs,
they were somewhat loose and started engine. Watched and lo and behold
the leak is at the oil cooler line adapter. It starte to seep out and I
hope that is it. I am about to remove the filter and adapter and
replace the gasket with the one off the folter that I just took off. I
hope this solves the problems.
Does any body have any other suggestions?
Marcus
Marcus
