Oil filter mount/adapter screen
tyler
516
96
28
My oil filter mount has a passage that ends in a screen. In the interest of "no bits of whatever tore up my engine" going back in the rebuild...what
is behind that screen? Rubber? metal? I have blasted brake cleaner in there from both sides, but I can't see it, so I'm not convinced it is clean.
http://www.gmcmhphotos.com/photos/data/6734/medium/S6300708.JPG
http://http://www.gmcmhphotos.com/photos/data/6734/medium/S6300708.JPGhttp://www.gmcmhphotos.com/photos/data/6734/medium/S6300708.JPG[/img
Rebuilding my motor is coming along...machine shop work all done, pistons and camshaft are in the block. Should have it all buttoned up by, I dunno,
maybe 2024? ha Project creep is strong with this one. Hoping to hear it run by end of March.
Raleigh, NC
I believe that is the pressure differential bypass valve. If the pressure differential in the entire cooler and filter loop exceeds about 4 PSI it
starts to open the poppet valve. Not the same as the internal oil pressure relief spring which vents oil back to the pump inlet above about 60 PSI.
