Bob Drews was a true gentleman and thinker and I do Miss him. Great at the lairs table too!
Granted that the oil seal is a square type rubber seal rings and works well for all the millions of filters used each year. The common practice, even by me over the years is to remove that rubber seal ring and use it to replace the rubber seal/O-ring on the oil filter adapter to the engine. There are a number of O-rings that can also be used in that application too. I changed my square type seal every time that I did an oil change.
http://www.gmcmhphotos.com/photos/455-2f-403-engine-oil-flow-path/p53706-dorman-oil-filter-o-ring-kit.html
This was researched and tested by Rob M and works well and I have also used it.
There are many options available, the choice can be yours.
J.R. Wright
GMC Great Laker MHC
GMCGL Tech Editor
GMCMI
78 GMC Buskirk 29.5’ Stretch
75 GMC Avion (Under Reconstruction)
Michigan
> I certainly do miss Bob Drewes. So knowledgeable and plain spoken. Used common sense to great advantage. Never boasted or built himself up.
> A true mentor for many of us.
> Only thing was his opinion on ethanol in fuel mandate and a certain shade of green. haha But that was good natured.
> May he rest in eternal peace.
> bdub
> -----Original Message-----
> From: Larry via Gmclist
> Sent: Monday, June 22, 2020 7:37 AM
> Subject: Re: [GMCnet] Oil filter base leak
> When I first started this GMC thing the Oil filter o ring was the only thing we had and was being recommended by everyone in the know. I had some
> leak issues. Got to talking with the great Bob Drews about the o ring and how it squashes out and leaks. He said…”Larry, think about that o ring
> and what it was designed for on the oil filter. It is a spin on and slides on contact for half a turn. You put a little oil on it so it slides to
> tighten. Your hands don’t have near the torque that a wrench has when tightening the filter adapter. And the oil filter adapter just tightens
> straight down with no twist and no oil on the o ring. So when you use the oil filter o ring, don’t oil it down. Put it in and tighten down dry.”
> So that is what I’ve been doing ever since. Never a leak. JWID
J.R. Wright
GMC Great Laker MHC
GMCGL Tech Editor
GMCMI
Michigan
> bdub
