Hi everyone,
I'm getting the engine ready to paint and have been mounting all the external components (timing cover, water pump, valve covers, etc). Now the last thing to mount is the oil filter/cooler adapter.
From my reading and previous experience with MG's, I knew there was a rubber o-ring between the block adapter and the cooler adapter. My hunch was that it was never replaced and so was probably a petrified chunk of rubber bound to start leaking soon.
Upon disassembly, I was right. So I've purchased the Dorman o-ring kit mentioned somewhere on the GMC MotorHome photos site.
It looks like a mechanic had worked on the lines previously, as they were 1/2" copper tubing (lol) and all the fittings had an obscene amount of teflon tape on them. The tape job was looking a bit sad so I decided to do a complete rebuild and remove/reseal all the plugs and fittings. I've also purchased SS oil cooler lines so the line connectors had to be changed out anyways.
Anyways, to my question:
Underneath one of the plugs was a spring. There is also what appears to be a poppet at the bottom of the bore. I'm assuming this is a pressure relief valve in case the cooler lines become plugged or something.
I'm not sure why this is required, as there is already a pressure relief valve in the block filter adapter.
I'm wondering if anyone knows exactly what this is and if there's a procedure for setting the appropriate relief pressure by torquing the plug or something? I'd hate to cause issues because I didn't set the proper spring tension on this valve.
I haven't seen any other posts mentioning the relief valve in the cooler adapter. My cooler adapter may not be OEM (this engine has been rebuilt, possibly replaced, several times). It has the words "Thermo Chem500 Pat #3463317" cast into it. The patent also makes no mention of a pressure relief valve.
See attached pictures. The first one shows the disassembled oil cooler adapter, along with the spring and plugs. The second picture attempts to show the poppet valve in the plug bore that the spring came from.
