It has been noted by long time owners over at GMCNet forum, that the top half to one quart of oil will burn off quickly in about 500 miles or so. The dipstick will then read just above ADD. If left at that level, it will stay there for another 1,500+ miles.
The general consensus is the higher level of oil in the pan gets whipped into a fog by the close clearances to the crankshaft. It then gets pulled through the PCV valve into the engine and burnt. Once the level drops a bit, this does not happen. Try letting the oil level drop a bit and monitor the consumption and see if it levels off.
So, the first bets are that it is nothing serious. Drive her, enjoy what she can do for you and plan to work on the engine when you are ready.
Matt, is this something that is serviceable typically or is this engine swap time?Marcelo,
I think your engine does have a problem. That lube oil consumption is pretty close to what mine was when #7 piston was missing about a third of its rings.
We do think that the engine has been apart at one point but have no idea when. We replaced the transmission just last month, so my brain is telling me we are due for an overhaul in general. I'd prefer to bite the bullet if we are talking engine swap, rather than jeopardize trips which are hard for me to make happen as is. Thank you for the insight, above. I will find someone here in the Portland area who knows these engines as step #1. What you are saying is resonating with me; we have good power, but the oil consumption is a bit ridiculous.Marcelo,
Do you KNOW how many miles are on this engine? Has it ever been apart? It may be time anyway.
It could be that the valve guide seals are shot and you got a set of the wrong valve covers. TZEs had special covers to reduce the lube oil carry over. Those could be serviced in place.
But the thing that should happen first is a cylinder leakage test. This is a better test than just cranking compression as it is very sensitive to the piston condition. If this says that there is a problem, you will know.
I knew in my case because I keep careful logs and when the lube oil consumption went from 2000+ per quart to 500 per quart+ I knew that something was wrong. She was only barely down on power.
There is a little leaking below the middle center of the engine area from what I can see. I am not sure how to look at plugs or what I would be looking for.How much is leaking ?
How do the plugs look?
Sent you a direct message!Hi there pdxbirchy...I am in Portland also and my 76 Eleganza has an oil burning and leaking problem as well. So far I have been unsuccessful in finding anyone in the Portland area who will even look at my coach...who did you find to work on yours? L. Miller
