That is positively true with conventional motor oil, but when you are
dealing with synthetics, the oil life is much longer, into the 25,000 mile
range provided you change your filter on a regular basis. You would be
watching the oil over the lifespan of a year.
To:
Sent: Monday, July 10, 2000 8:12 PM
Subject: Re: GMC: Oil Analyzed
> Bob while the tests may show this, it is not useful information in my
> opinion. If there is antifreeze in the oil believe me you will know it.
And
> the information is useless unless you detect the antifreeze early on. HOw
> often are you going to test the oil at $10.75 per test (does that include
> shipping and other add ons).IN addition if you change your oil correctly
you
> will know if there is any metals in the oil(there always is). Im sorry but
> good preventative maintenance is the best solution along with knowledgable
> people to work on the coaches.
> tom
> >Tom,
> >I will post tomorrow the specific tests done with Mobil test sampling.
Test
> >kits should run about $10.75 per test. The beauty of this testing is it
> >allows you to over time, they keep track of your engine, to see the
changes
> >in the engine oil composition. So if for instance on your last oil
change
> >it suddenly shows antifreeze in the oil that wasn't present in previous
oil
> >changes you know you have a problem. The same is true when metals
present
> >in the oil sample.
> >bob neeb
> >From: tom warner
> >To:
> >Sent: Monday, July 10, 2000 5:38 PM
> >> That in effect was the point I was going to make Tony. In my opinion
there
> >> is little meaningful information to be gained by doing an oil analysis
on
> >> the olds 455 engine. I once workded in a Precision Measurement
Equipment
> >> Laboratory on an Air Force base and had access to many of these oil
> >analysis
> >> tests. As far as I remember only in one instance did I ever see the oil
> >> analysis used and that was for the large diesels used in the bases back
up
> >> power generation. For those diesel units the oil was never changed.
> >Instead
> >> the analysis told the tecnicians what and how much additives to add to
the
> >> oil to make it perform to specifications. Only the filters were changed
> >and
> >> a appropriate amount of oil added.
> >> In the case of the olds 455 I do not think there is any meaningful
> >> information that could be obtained over and above tehe information that
is
> >> obtained during an oil change.
> >> For instance many dedicated owners split their oil filters and inspect
the
> >> contents during each oil change and companies like Summit racing sell
> >> products exactly for this purpose. IN addition when changing oil smell
> >and
> >> feel it after you collect it in the waste pan. The texture and smell
tell
> >> you a lot about the condition of your engine. Also the oil filter plug
> >> contains a small magnet and it should be inspected for trace amounts of
> >> metalc and the amounts and kinds sometimes alerts you to t things that
are
> >> going on within the engine.
> >> Whats the best thing to do to your engine. Make the oil and filter easy
to
> >> change and change it wiht good quality oil every 3000 miles
> >> just my thoughts.
> >> tom
> >> >Several years ago I worked for a company that manufactured filtration
> >> >systems. One of the customers was General Electric, which was
supplying
> >jet
> >> >engines to Grumman, to be used on military planes. We were analyzing
oil
> >> >from these jet engines. We gave them a breakdown of particulate
> >composition,
> >> >which metals were most prevalent. Knowing the metallic composition of
> >each
> >> >engine part, they could then use this data to determine what parts
were
> >> >wearing, and if they were wearing more than expected. I once asked
what
> >they
> >> >did with this information and was told "not much" as they usually
> >replaced
> >> >the engines long before anything ever wore out. As I got my puny
> >paycheck,
> >> >and saw how much taxes were being taken out, and couldn't help but
marvel
> >at
> >> >yet another example of tax dollars well spent.
> >> >I don't know of any place that will analyze your oil, but unless you
know
> >> >the metallic composition of various pieces, the information may not be
> >all
> >> >that valuable.
> >> >Just my 2 cents (less taxes taken out to replace jet engines that
aren't
> >> >worn out yet... so 0.8 cents)
> >> >Tony B.
> >> >From: tom warner
> >> >To:
> >> >Sent: Monday, July 10, 2000 3:15 PM
> >> >> Im interested. What do you hope to find out from the oil analysis
and
> >what
> >> >> will you do with the data you receive?
> >> >> tom
> >> >> >> GMCers
> >> >> >> A long time ago we used to send the oil from our race cars off to
> >> >> >> be analyzed. We would get a report back telling us all sorts of
> >> >> >> stuff. It would tell us how wear was going. How much life was
still
> >> >> >left in
> >> >> >> the oil ect. That was 30 some years ago. Does anybody know who
is a
> >> >> >> good company to do this now? Someone involved with fleet
operations
> >> >> >> should know of this service. If any of you know of a good company
> >> >> >> please holler. I want to get the oil analyzed that I take out of
the
> >> >> >> GMC
> >> >> >> this Thursday. TIA
> >> >> >> Take Care
> >> >> >> Arch
> >> >> >I send my oil out every couple of years for analysis but the data
is
> >at
> >> >> >home and I am not. Ask any Amsoil dealer. That is where I bought
the
> >> >> >kits.
> >> >> > David Lee Greenberg
> >> >> > The GMC Motorhome Registry
> >> >> >Dedicated To The Preservation of the Classic GMC Motorhome
http://www.GMCss.com/Registry.htm
http://www.Buskirk-RushRV/GMC-Registry/online-registry.htm
