Oil additives
1976GMC
260
39
28
Washington State
Do any of you have experience with Lucas Heavy Duty Oil stabilizer? A mechanic had recommended that I use it in one of my old work trucks that has a
bit too high oil consumption. Any one here on the forum used this product? Care to share your experience?
Also, to bring the topic back to GMCMH, is it a good product to use in our engines?
Vadim Jitkov
'76 Glenbrook 26'
Pullman, WA
If you have to add stuff to your oil, you are buying the wrong oil.
Often adding things upsets the chemistry and degrades the oil's ability to lubricate as well.
Yes, GM, makes a product called EOS. I use it in the break-in oil when
flat tappet camshafts are installed. It drains out with the oil when 500
miles are on the clock. Other than that, I use dino oil. Usually Valvoline
20 - 50 in a very high mileage 403. Other than that, no additives.
78 GMC ROYALE 403
On Tue, May 29, 2018, 3:13 PM John R. Lebetski
> lubricate as well.
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
Our first 78 Royale had 154,000 miles on it when the frig burned it up. Had the log since new. Always had 10/30 dino oil used in it. No additives, or synthetics. Compression was 135 to 145 lbs. Hot oil pressure was at 35 psi. Used a qt in 2200 miles. It's going in another GMC as is. Bob Dunahugh 78 Royale
