Norcold Fridge
steven d. ferguson
874
Did you purchase the Norcold 641 frig???? Anything you can tell me
would be
appreciated. You can reply over the net. Thanks.
Jerry,
I did. I used it for about 2 months, then on a trip, then to keep the
beer cold while I worked on the rest of the coach. It crapped out in 6
months. I called the place where I bought it, they had me take it to a
place authorized by Norcold (close by). They never even looked at the
receipt, they just ordered me a new cooling system and installed it for
free. Excellent response. BTW, there was a small crack in a line
leading from the heater. It does work good. Best on propane, darn good
on 120vac, sorta kinda on 12vdc. (Good enough for keeping things cold
while in motion. The propane works well while underway, I've run 75-80
and nothing seems to extinguish the flame. It also seems like the tank
never goes down either. Installation was easy, I had to poen up the top
of the existing framework 1/2" to make it fit. Took 10 minutes.
Running the propane line took a bit longer, but wasn't too difficult.
Steve F.
