Marcus, the Holley injection was on the coach I bought it and I like
it fairly well. However there are 2 versions, one is for big block and
one for small block. Also, there is an option for closed loop control
with exhaust sensor. I believe this would be very desireable what with
todays gasoline and would help prolong engine life. It starts easily
and seems to run good. No calibration on gas mileage yet.
I had a go around with the fuel pump loosing prime with gas below 1/4
tank on a hill. It would not prime until I had 1/2 tank on level
ground.
I have the manual if you have any questions. Holley also has a web
site (holley.com). Hope this helps.
Bill
'74 Glacier
>>>> clip
Date: Sat, 26 Jun 1999 17:11:37 -0400
Subject: GMC: Holley 670 CFM Projection - Any comments good or bad?
I have a chance to buy a used Holley Projection 670 CFM two barrel
system with the electronics. It was removed from a 302 truck engine
and needs the cable harness, but the price is right - under $200. Any
Do You Yahoo!?
ground.
Bill
'74 Glacier
>>>> clip
Do You Yahoo!?
