>Toro distributor module in their coach?
>Just wondered how it would react? Ping
>alot due to a faster advance curve
>perhaps?
The TP-45 type ignition module does not control advance and
changing the module should have little effect on the timing
or ping, if the module is to spec.
>Anything else I should be aware of here? Adv
>springs or weights?
Absolutely, the springs and weights as well as the vacuum
control how much and when ping. If you want less pings when
the throttle is applied you want the vacuum control to
react more quickly (the vacuum control retards the timing
as you apply throttle) an adjustable Vacuum control is
available under the ACCEl brand for HEI distributors.
>From: owner-gmcmotorhome
>[mailto
wner-gmcmotorhome]On Behalf Of
>chase
>Sent: Tuesday, June 06, 2000 4:43 PM
>To: 'GMC'
>Subject: GMC: HEI Module
>Out of curiosity has anyone ever had a
>perhaps? Or would you have to retard it
>more than usual to compensate for the
>quicker advance? Just some thoughts...
>I retarded mine early this AM to 10
>degrees advance at 600 rpm (with vacuum
>adv blocked off) which is less than the
>12 degree adv. the Caspro EKE
>instructions call for. I still get a few
>seconds of ping every so often under
>load. Heck, if I goto 8 degrees to stop
>the ping what's the sense of having the
>EKE sensor in the first place?>
>I would like to get it to the point of>
>1,2 or a few pings but 3-4 seconds worth
>seems like a lot to me. Maybe my best
>bet is to simply replace the HEI module
>and use this one as a spare. Anything
>springs or weights? Suppose I shoulda
>probably sent the darn distributor to
>Caspro when I got it back from JB in
>Forest City.
Is the NAPA (TP45) or the Delco
(1875990) module any better than the
other?
Nate '75GB (Ping, ping, ping... EKE!)
Omaha
Alan Bredbury
Clinton, Ct.
1974 GMC 26' Classic Motorhome
http://www.finesttool.com/index.html/special.htm
Do You Yahoo!?
Yahoo! Photos -- now, 100 FREE prints!
http://photos.yahoo.com
>perhaps?
>springs or weights?
>[mailto
>chase
>To: 'GMC'
>Forest City.
other?
Omaha
Alan Bredbury
Clinton, Ct.
Do You Yahoo!?
