Spent an hour watching a video about trouble shooting the Rochester Quadrajet secondary problems. What an eye opener!!
Checked my GMC quadrajet #7043254 that had been rebuilt several years ago and installed by me following detailed instructions from the rebuilder. Was
never happy with the performance, but the rebuilt card had undergone dyno testing and 3 gas measurements so I figured this would be as good as it
gets.
Found the Single hole carb to intake manifold gasket supplied was interfering with the opening of the secondary butterflies. Butterflies were only
opening about 10 degrees of normal 90 degree rotation. Could even see the wear marks on the gasket looking down through the throat.
Removed the gasket and removed the interfering areas and reinstalled the carb and gasket being very careful to follow the torque sequence and values
in the maintenance manual. Was delighted to see full 90 degrees of opening when I worked the butterflies from the carb mechanism. I was expecting a
big jump in performance.
However, when I floored the accelerator pedal, the butterflies opened only 10 degrees again. The accelerator cable has been stretched from all the
years of pulling against secondary butterflies with restricted excursion. Will talk to my rebuilder today about the damage to the accelerator cable.
Looks like about a $100 item from various suppliers.
Also, raw fuel was seen inside the intake manifold when the carb was removed. When I looked at the styles of the carb to intake manifold gaskets
available in rebuild kits, only two styles are available: 4 hole or 3 hole. The one supplied to me originally had only one huge hole. I am wondering
if my one hole design is not properly blocking some passage on the underside of the carb causing fuel to dump into the intake manifold. I suppose the
float could be stuck and the fuel bowl overflowing but would it leak into the intake manifold? Most of the gas was pooling on the passenger side of
the intake manifold. I never checked the underside anatomy of the carb when I had it off to see if a passage should have been sealed off by the proper
gasket. After watching the video, I am only a secondary butterfly expert.
Thanks for your assistance. I am in awe at the carb knowledge displayed by posters on this forum and know that a properly functioning quadrajet is the
closest carb to fuel injection performance out there. However, I am being drawn to the fuel injection option to eliminate some of these potential
screwups.
gets.
screwups.
