Hi Dolph: in the 77-78 maintenance manual supplement (3A-2 Front Suspension) it says to adjust the intermediate rod parallelism of the steering to
the lower control arms by adding washers under the idler arm. Since the relay lever is on the same working plane as the idler arm I might recommend
checking your parallelism and see if you need any adjustments and go from there. I would pry up and down on the relay lever to see how it effects
measurements. This should tell you if you need to add washers or remove metal from bushing.
Make sure you check your tire air pressures and ride height before checking parallelism as it does effect it.
Hope this helps..
> Jim:
> Seven plus years of looking at the shop manuals, and not once did I crack open the Parts manual.
> I did now, and wow. Thank you, Jim.
> Matt, the front frame I dropped off has the relay lever bolt with a lock washer. That's not what it shows in the book.
> Now for the fastener mavens - the bolt on my relay lever bottoms before squeezing the assembly properly, allowing the Dave Lenzi lever to move up
> and down a little more than .100
> So, two grade 8 washers, or do I fire up the lathe?
> Dolph
> DE AD0LF
> Wheeling, West Virginia
> 1977 26' ex-PalmBeach
> Howell EFI & EBL, Reaction Arms, Manny Transmission
> "The Aluminum and Fiberglass Mistress"
> > I would strongly advise you to read the parts manual. Every nut, bolt,
> > stud, flat washer, lock washer, etc is clearly identified in the
> > descriptions, and drawings. The way the GMC factory installed it. Then go
> > from there.
> > Jim Hupy
> >>> I know this seems like a stupid question, but my 75 Palm Beach 455 has
> >> very few flat washers or lock washers in the engine bay. (except on the fan
> >>> shroud) My years with German cars, and climbing radio towers, we had
> >> flat and lock washers on EVERYTHING. I went out and bought a bunch of spare
> >>> washers, just in case, and now upon re-assembly, from the water pump
> >> out, I am wondering if this is overkill and even might be sacrificing
> >>> reliability, by having less thread into the cast iron and other
> >> assemblies. Yes this is my first American car real work, and you would
> >> think at 66,
> >>> I would know, but I don't. Porsche 8mm nuts (13 mm socket) had average
> >> of 18 ft lbs of torque, I'm really not used to this, it is a whole different
> >>> world.
> >>> Thanks,
> >>> Jack
> >> Jack,
> >> SAE lock washers will seldom do any harm, but in high load situations they
> >> are quite useless. An SAE lockwasher (the kind with a sheared angled ends)
> >> is supposed to work two ways:
> >> First is that it is a spring to keep tension in the fastener should it
> >> have the opportunity to loose tension.
> >> Second is that those two sharp edges are suppose to grab something and
> >> prevent the rotation of the fastener.
> >> The only problem we (ASTM Bolting Technology Committee) found was that
> >> during an uninstrumented assembly (no torque wrench or other), the
> >> compression
> >> of the spring in the lock washer did, in some cases, cause the assembling
> >> technician to over estimate the achieved tension in the fastener.
> >> (Non-techese - He didn't get the screw as tight as he thought he did.)
> >> So, put in lockwashers as long as you don't sacrifice engagement for it.
> >> Matt
> >> Matt & Mary Colie - '73 Glacier 23 - Members GMCMI, GMCGL, GMCES
> >> Electronically Controlled Quiet Engine Cooling Fan
> >> OE Rear Drum Brakes with Applied Control Arms
> >> SE Michigan - Twixt A2 and Detroit
> >> GMCnet mailing list
C. Boyd
76 Crestmont
East Tennessee
