No spark- the sage continues
dave silva
1,090
So, i order the "same" distributor from Amazon- $60. But it's the wrong one- the gear and the shaft are defferent.
But ALL the electronics are identical so i swap the coil and, what i assume is the control module. and the coach fires right up, like never before,
starts instantly without touching the pedal.
Today i go to move the coach and it won't start, I have power to the distributor and no spark.
Any ideas other than cheap parts with a high failure rate?
Dave & Ellen Silva
Hertford, NC
76 Birchaven, 1-ton and other stuff
Currently planning the Great american Road Trip Summer 2021
It's gonna take a lot of Adderall to get this thing right.
Probably the module but you didn’t change the pick up coil did you
Roy Keen
Minden,NV
76 X Glenbrook
Did you add an additional ground from the distributor base to the block? Than can help.
> Roy Keen
> Minden,NV
> 76 X Glenbrook
Take the cap off and check all internal connection and wires not pinched.
> Than can help.
> > Roy Keen
> > Minden,NV
> > 76 X Glenbrook
Jim Kanomata ASE
http://www.gmcrvparts.com
