Nipples
j dexter
77
Salutations:
Thx Messers Zingle, Brandt and Ms Meineken.. I will investgate our elephants' nipples further.. ;) ..
Re: LP Water Heater, if heat exchanger mod wouldn't work, surely you could patch directly into chimney for fridge to vent LP Water Heater.. This would probably preclude Drive n' Heat piping however.. or a least make a bit of a birds nest behind there..
I guess we would really want well shielded chimney flu though as it would get pretty hot for surrounding plastic en-route to fridge chimney.. Or, consider moving whole water heater above LP Fridge so as to share stack..
I wouldn't want to feed chimney below the Fridge as water heater chinmey would heat the fridge coils all the time it was on.. I was speaking with local 'Propane and Propane Accessories' man and found out that ALL these fridge coils and cores are made by one outfit in Italy and sold under different trade names in different boxes around the world.. and they cost like SOB to replace with new ones if you need to..
I am reminded of one of my fav movies "Your automobile is operating as envisioned by the designer - to avoid carbon on the valves you must never proceed in any forward gear at anything less than 3,000 RPM.. " .. ;) ..
your pal on the north atlantic
J Dexter
'77 PB -
