> What year is your coach? Is it a Power Level, Electro-Level, or
> Electro-Level II system?
> The Power Level system is entirely pneumatic except for the pump, and uses
> a large (~a gallon) storage take mounted up front. The pump's job is to
> keep that tank at a pressure always higher that the bags. When the coach is
> low, the leveling valve opens, feeding air from that tank to the bag. When
> it is high, it dumps bag air to the outside. The pump has to run from time
> to time even when you have no leaks, because it is not a closed system.
> I rebuilt my Dana using a kit from Mr. Clement, and not too long after that
> replaced it with a Viair. The Dana required much more time to pump that
> tank up to the 125 psi required by the pressure switch.
> 25 minutes without a reading from a known-good pump, though, tells me
> something is much more wrong than a tired pump or a slight leak somewhere.
> It tells me the check valves aren't letting air in, the pump/system is
> plumbed incorrectly, the gauge is dead, or something significant like that.
> Rick "who gets a read in a few seconds with any pump" Denney
> On Sat, Sep 14, 2019 at 8:00 AM tonka6cuda6--- via Gmclist <
> > Im on the fence with you guys as well....i have my original DANA that i
> > took out as it wouldnt pump air worth beans and i replaced it with a known
> > good DANA....sadly it really doesnt do the job either.
> > I read all these stories about how that DANA does the job but either i
> > have a monstros air leak (which i dont) or im not letting it run long
> > enough to
> > build pressure (i think over 25 minutes without air pressure on the gauge
> > is not right).
> > I just dont see how a 1/8 inch line coming out of compressor can put
> > enough volume into the system to build air effectively or reasonably quick
> > enough.
> > Now to be fair maybe the line coming out of the compressor is supposed to
> > be bigger but i cant find a size? Im using a 5psi crack pressure one way
> > check valve so maybe its to strong,? (That is the recommended crack
> > pressure btw)
> > So for me its a toss up....do i pull the DANA again and replace it with a
> > Viair or try to make the DANA set up work......
> > Rich Mondor,
> > Brockville, ON
> > 77 Hughes 2600
> '73 X-Glacier 230 "Jaws"
> Northern Virginia
> Offlist email: rick at rickdenney dot com
Electro level 1 on mine....if i use my commercial air compressor everything works perfectly....the DANA just doesnt have the volume and/or the
pressure. Im not and engineer, i am a mechanic that works with air systems every day.
As i said, something is amiss on mine....its either the compressor or/and the line size from the compressor to the tank because if i had to guess its
not making over 5psi to crack the valve open....if thats the case it will never add air. (Plus even if it was there is 100psi on the other side of the
check valve that it must overcome and its not doing that for sure)
Rich Mondor,
Brockville, ON
77 Hughes 2600
