New Torsion bars from Manny
Manny made the hex section londer so it fills the A frame the full length
so that it lessens a chance of the hex sleeve in the A frame from rupturing.
I have seen several rupers of A frames on customers coach.
We are stocking Manny's units, and know it will be worth the swap.
On Fri, Nov 25, 2016 at 2:30 PM, Ken Henderson
wrote:
> Jim, et al,
> The problem I had with the lower control arm was that I got one of the
> first 1-Ton kits Manny delivered. While he'd had the socket reinforced,
> they missed that mine was already "blown out" and didn't reinforce that
> area. As soon as Manny saw my damaged socket, he improved the
> reinforcements for subsequent deliveries.
> The extended forward hex end on Peter's bars (and hopefully Manny's) will,
> IMHO, both prevent further damage and, probably, correct already-damaged
> lower control arms.
> Of possible interest to someone: While evaluating my situation with that
> problem A-arm, I talked to the owner of SuperMax, the company that makes
> the adjustable porkchops sold by JimK. He prototyped an adapter which can
> be used to adapt the later GM torsion bars to the GMCMH. It's a 1-1/2"
> female socket to 1-1/4" male hex adapter which fits into the GMC's A-arm
> socket and accepts the later torsion bars. At the rear, the SuperMax pork
> chop, with the 1-1/2" aperture must be used. That device SHOULD make it
> possible to choose one of the modern torsion bars with no other changes
> (the adapter corrects for the shorter modern bars). I emphasize SHOULD,
> because AFAIK, only the one prototype has ever been made and that never
> fitted to a GMC.
> Ken H.
> > ... I know that Ken Henderson had some kind of problem with his,
> > but I do not know what exactly the trouble was. It was at his suggestion
> > that I specified extending the hex end by 1 inch on Peter Huber's new
> > torsion bars. Hopefully, due diligence and maintenance will prevent any
> > more issues.
Applied/GMC, Fremont,CA
JIM HUPPY
I'd like to make some conclusions and state my situation to frame a question if I may.
I do have a Manny One ton installed in my coach. I'm not really sure it is a first generation or not. (I did have the swelling outer boots from the
grease rubber incompatibility and the regular Ball joint bolts) The HEX section in the Lower Control Arms have a strap welded onto it. I'm assuming
that is some of reinforcing you are talking about.
I bought the original torsion bars from Peter because I felt that the front end seemed pretty soft (a lot of stroke even after getting the correct
ride height) after installing the one ton.
You've installed a number of the "Huber" Torsion Bars. You've also installed a number of Manny / Huber Combination front ends. I think I'm
understanding that you are saying that you have not experienced a situation where the bar has torn out the hex section of the Lower Control Arms in a
Manny/Huber Combination.
Ken Henderson is saying his problem was because the control arm was already bad before installing the torsion bars.
I fully understand in the manufacturing business that products are constantly improved and specifications change for many reasons, and in this
situation, the improvement does not necessarily mean the original product was not suitable. I'm hoping that the original Huber bars that I have should
still be suitable for my use.
Jim is saying he has seen several ruptures on customer coach's but did not say if they are from Huber first generation bars or OEM or if they were
Manny One Tons or OEM front ends.
I do not use my coach during winter and road salt conditions and I did inspect my lower Control Arms for wear when I installed them ( I remembered
Kens problem)
While my opinion is things will be fine:
Do you think I will be OK?
Best regards
John and Cathie Heslinga
1974 Canyonlands 260
455, Manny tranny and 1 ton, 3:70 LS,
Red Seal Journeyman, DTE, BEd. MEd.
Edmonton, Alberta
