New Item -- seams
thomas g. warner
1,863
You might think about using rubber roofing for the seams. you can get it in
rolls about 4" wide and it is self sticking. Very durable and tough.
Camping world has it for sale in black and white
>Did you ever try taking off the decals on the sides of the coach? Pretty
>tough job hey what.
>I had new stripes put on my coach 3 years ago, where they go over the joints
>in the body the stripes hold fast, no sign of it coming loose from the body.
>I got a color chart from the fellow that stripped my coach, matched up a color
>the same as my coach. He is going to get me a 2" x 50' roll of this stripping
>material. I am going to clean up my seams on the roof real good and then put
>this 2" stripe over the seams. I'm sure this will prevent leaking if any.
>Ed
>75 Landau
>NJ
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
I have the 'seam' problem in spades!! The Transmode I am converting back to
motorhome use was originally an EPA mobile air quality test lab, and they
had approx 12 fans and probes that used to stick out of the roof. I have
been using sheet aluminum and riviting patches over each of the holes they
cut. My question is about the liquid rubber roof material that camping
world sells??? Would this a good idea to put this coating over the entire
roof, from front to back seam-to-seam?? Any experiance out there??
p.s. I wonder how the EPA ever got good readings with the vent from the
black water tank still installed and only 3-5 feet away???? Maybe this
explains where some of the new air quality regs come from.......
>>tough job hey what.
color
stripping
put
>>Ed
>>75 Landau
>>NJ
>Tom & Marg Warner
>Vernon Center NY
>1976 palmbeach
