That is correct. You put in the new fluid in the pan and let the
transmission pump it to the torque converter and cooler, thereby displacing
the old fluid with the new fluid. You let the old fluid out by letting it
escape via the return line from the cooler. You want to put in the extra
new fluid in the pan so you do not starve the pump when you let the fluid
out via the cooler line. I have not done this but have been told by a
couple of transmission people that is the way to change all the fluid. You
probably could get a transmission shop to do the fluid change for you if you
could find one that you trust. I am very picky about my transmission
mechanic as I have had a lot of bad experiences with them. I work on a lot
of airport ground equipment and finding a good transmission mechanic is
difficult to find and they seem to keep moving around from shop to shop. I
would talk to an old time native of Branson to find out who is good.
I am told that the Mobil 1 synthetic is compatible with the dextron
transmission fluid.
Russ Bethel
rbethel
transmission fluid.
Russ Bethel
rbethel
