new disc brakes
Nov 8, 1999
150
Just completed my first trip over to eastern Washington with the new brakes.
The trip over was thru Snoqualmie pass and the trip back thru White pass.
Now I want to tell you I think Disc brakes are fantastic. It has changed my
GMC into a sports car compared to what I had before. I machined the backing
plates out of 3/8" mild steel plate and used Camero front calipers. For the
disc I used rear discs from a Lincoln Continental. New off the shelf they
were $26. The biggest problem was bleeding the rears. I was careful to mount
the calipers with the bleeder port up. Come to find out that with the
internal porting I was still having problems getting all the air out. Ended
up with dismounting the caliper and placing a C-clamp on the piston to keep
it from expanding, then bleeding the caliper while rotating to get the last
of the air out. I also went to a larger master cylinder. Still am getting a
lot of travel. I will bleed one more time next week to see if it helps. At
low speed (less than 5 MPH) the brakes do not lock up like drums. But, at
speed, they start getting hot, and the hotter they get the better they stop.
I am not an engineer so don't ask me why, just works that way.
Things I would do differently.
I would design the backing plate around calipers that would interchange with
the front. and I would be a lot more careful of the bleeder placement. Most
of all I would have done it a lot sooner........................Terry
Terry & Diane Skinner
Webfooted in Washington
great report
thanks
gene
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
