New timing chain installed and radiator back from the shop (one small pin hole repaired). Everything is starting to go back together. I found a set
of new belts in the coach and because I plan on replacing the belts that I took off I am wondering if I should get a brand new set and just keep these
around in case of a failure or use them and buy a new set to carry along when we start to travel. Either way I will have an extra set but if there is
a chance that they age out like tires I would put the new ones on and keep these for ICE. If on the other hand they don't age out when stored just
use them and get a new set when we start to use the coach to travel. Could still be a spell before it is ready to travel.
Thanks for any opinions on this.
Melbo
Melbo
