>GMCers
>Good news to report. My GMC now drives very well. It no longer
>darts from side to side. There were several problems. First the front
>ride height was 2 inches low. The back was 1/2 inch high. The toe in
>was set to 0. I also had 3 bent bogie arms. The only one not bent
>was driverside front. Now it even goes where I point it. At 55 MPH
>she will track straight enough to let go of the wheel. Life is good.
>Once again I would like to thank Jim Bounds for all of his help.
>Take Care
>Arch
Arch - glad to hear that you've got it working so well. Once it is
adjusted like it came from the factory it should actually drive quite
well. After that base adjustment is done then one could experiment
with such things as changing the toe, the camber, etc. to personalize
the handling. If I recall, Tom Warner, basically said this when he
said something to the effect that drawing conclusions from a single
adjustment meant nothing unless we were aware of the other settings
such as ride height, alignment, etc.
How did you finally decide to do the rear alignment? Did you use
shims or did you have the arms "rearced" (bent)?
Santa Fe, NM
>Take Care
>Arch
Santa Fe, NM
