Need to figure out how to get it out. From what I see. When putting things back in. Wouldn't it be simpler to make the radiator shroud into a two piece. With, lets say, a 3 inch extension of the plastic shroud to the rear. Trod the engine. And forget the horse collar it's self. Putting in a Cardone roller water pump, new clutch fan, belts, and hoses. Need to remove fuel pump. As I'm putting EFI on the 455. Plus I want to look in to see if the cam gear is alum/plastic. If so. That will need to be changed. I'll never make a dime on this build at this rate. Bob Dunahugh
