Needed: Walbro Carb
jerry sitzlar
185
I can't keep patching the repairs made by a PO on my 6K Onan carburetor. I know these are made of Unobtainium, but maybe someone has an old one
lying around. If you do and you're willing to part with it then please PM me.
Thanks,
Jerry
Jerry Sitzlar..... 77 Eleganza II, Twin bed, dry bath......
Lenoir City, TN
> You can buy the kits or a whole carb from Applied GMC. appliedgmv.com
http://appliedgmv.com
Or go to propane and forget all rhe gas related issues
> Emery Stora
> > On Sep 16, 2017, at 11:15 PM, Jerry Sitzlar via Gmclist <
> > Unobtainium
Alternator Protection Cable
What kind of patching was done?
If he body is good a rebuild kit should fix any problems.
pretty simple carb.
I have rebuilt many carburetors throughout the years, so that is not the issue. When my Onan started running way too rich, I ordered a rebuild kit
from Jim K. I found several issues with my carb when I removed it, including several patch areas of epoxy on the body (?), a nozzle boss that looked
like it had seen better days, a ground off idle screw, a bent float, etc. I have a NOS Walbro LMB carb, that I cannibalised to get a new float. The
NOS carb did not have the same jetting etc, that the Onan employs so I could not use that carb. I put in a new idle screw and the repair kit,
installed the carb back onto the Onan and it started and ran, but it is still too rich and cannot be adjusted at the idle screw. The power screw
adjusts great. The Onan puts out the correct voltage and frequency at load and no load. The idle smooths out a little whenever the filter is
removed (new filter) and the carbon is removed from the new spark plugs.
I believe there is internal damage in my carb and it cannot be rebuilt. If I can buy a used carb from someone at a reasonable price I may be able to
rebuild and use it or use it as a core for a Jim K unit.
Thanks,
Jerry
Lenoir City, TN
Jerry,
I have a rebuilt one which you can have; unfortunately it is in Australia and I don't get back until December 13th.
If you can wait I'll ship it to you FOC since you're a nice guy! :-)
The Pedantic Mechanic
Sydney, Australia
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Jerry Sitzlar via Gmclist
Sent: Sunday, September 17, 2017 12:59 PM
Cc: Jerry Sitzlar
Subject: Re: [GMCnet] Needed: Walbro Carb
ordered a rebuild kit from Jim K. I found several issues with my carb when I removed it, including several patch areas of epoxy on
the body (?), a nozzle boss that looked like it had seen better days, a ground off idle screw, a bent float, etc. I have a NOS
repair kit, installed the carb back onto the Onan and it started and ran, but it is still too rich and cannot be adjusted at the
idle screw. The power screw adjusts great. The Onan puts out the correct voltage and frequency at load and no load. The idle
smooths out a little whenever the filter is removed (new filter) and the carbon is removed from the new spark plugs.
I may be able to rebuild and use it or use it as a core for a Jim K unit.
Thanks,
Jerry
Rob,
Thanks for the generous offer which I gladly accept. If something else should come up between now and the time you get home, I'll let you know.
I'll gladly compensate you for the time, expense, and trouble. These things are like hen's teeth.
Since you're traveling I assume you're feeling better. This time last year I was recovering from torn glute muscles and now, the wife is recovering
from injury to her left leg, so now I'm taking care of her. We were worried because she had both hips replaced twenty years ago. None of this stuff
happens during the winter when we're mostly dormant. At least I got most of the stuff done this year on the GMC that I wanted to accomplish last
year, just the Onan slowing me down. So...............havahappy.
Jerry
Lenoir City, TN
The GMC spirit is alive and well on two Continents ...thank you Rob !!
On Mon, Sep 18, 2017 at 6:27 PM, Jerry Sitzlar via Gmclist <
> Rob,
> recovering
> stuff
> Jerry
> Jerry Sitzlar.....
> Lenoir City, TN
Michael Beaton
1977 Kingsley 26-11
1977 Eleganza II 26-3
Antigonish, NS
OK, I found a NOS carburetor on eBay for $50. I installed it today, hit the start switch and the gen cranked but did not start. Did a quick check
and did not have a spark, it was my 41 year old coil. Luckily I had ordered one from Jim K last month for a spare and installed it. This time the
engine fired right up with my new carb not even needing adjustment. Sometimes things just work out.
Rob, I really do appreciate your offer, but I don't need one now, so you get to keep your spare. The next time you get back over to East Tennessee
give me a call and I'll gladly give you a hand with whatever you're working on.
Jerry
Lenoir City, TN
What a deal $50.00.
What carb did you get?
I got the carb that fits the 6K generator. He thought it went on a go-cart engine. I also got a used one for more money from another eBay source
that I will rebuild and maintain as a spare. I also managed to get several floats for the Walbro LMB carbs. :d
Jerry
Lenoir City, TN
Jerry,
Okie dokie! Good things happen to good people! :-)
Sydney, Australia
Sent: Saturday, September 30, 2017 9:34 PM
Cc: Jerry Sitzlar
Did a quick check and did not have a spark, it was my 41 year old coil. Luckily I had ordered one from Jim K last month for a spare
and installed it. This time the engine fired right up with my new carb not even needing adjustment. Sometimes things just work
out.
to East Tennessee give me a call and I'll gladly give you a hand with whatever you're working on.
Jerry
bath......
Lenoir City, TN
