Need plumbing advice, please?
mike
860
Hello All, I hope everyone is enjoying this winter, it has been quite cold and snowy in most parts of North America... Ontario included.
1975 26' Coachmen built Royale with dry bath.
I'm working away on getting the GMC ready for the spring and was hoping to address an issue I noticed last autumn. While running the water in the
front lounge sink (just happened to be this sink but it happens with the bathroom sink as well), after a couple of minutes I notice the water rises up
from the shower drain and into the shower.
While trying to diagnose why this is happening, and I'm no plumber, you could hear some gurgling sounds as the water builds up into the shower.
Looking over the existing plumbing to determine drains and vents etc it appeared there isn't a direct drain vent, at least one that we could
identify.
We tried snaking out lines, both drain and vent to try and clear any obstructions or clogs, did the best we could and because testing afterwards
yielded the same result we looked at installing a new vent line. There is a vent line in the bathroom that ties the main drain line into a vent pipe
but we thought it might fix the issue by adding another vent a bit further downstream towards the rear of the coach... no luck.
Here is a photo with a little description... http://www.gmcmhphotos.com/photos/my-75-royale/p64479-image350.html
A = the existing drain line from the front lounge sink past the bathroom which disappears into the floor next to the generator enclosure, assuming
this goes to the grey tank?
B = the newly added vent line connecting the main drain to what I believe is the black tank vent.
C = the existing vent line from black tank up through the roof via the bathroom.
What am I missing here, the only other possibility I can think of is that there should be another vent somewhere direct from the grey tank to the
atmosphere? If this is the case where should I be looking because I haven't seen one yet?
Or should I be chasing an obstruction somewhere?
As always your guidance is appreciated,
Mike
What's the chance one of the tanks isn't draining properly?
If it’s backing up into the shower pan your holding tank must be full.
You should check your drain valve. It probably is broken so that when you pull the rod to drain the slide valve isn’t opening.
Or something is clogging the drain exit.
Perhaps someone has been dropping “wet naps” into the toilet?
Frederick, CO
> --johnny
> Braselton, Ga.
> --johnny
Hi Johnny, this past summer I drained both tanks, there wasn't much in them except when I filled the grey water tank for testing, both showed no
significant signs of slow drainage.
Thanks,
Mike
> If it's backing up into the shower pan your holding tank must be full.
> You should check your drain valve. It probably is broken so that when you pull the rod to drain the slide valve isn't opening.
> Perhaps someone has been dropping "wet naps" into the toilet?
> Emery Stora
> 77 Kingsley
> Frederick, CO
> > --johnny
> > Braselton, Ga.
Hello Emery, I purchased the coach in October of 2016 and nobody has been using the toilet since I have owned it. I did a renovation and removed and
replaced the toilet during last winter.
I did drain both tanks this past summer and as mentioned above I never noticed any slow drainage, even when I filled the grey tank and drained it, it
appeared to drain well. I have no previous history or knowledge of what it should drain like but it seemed to flow quite well.
Thanks,
Mike
I dont think this is a common problem, so I would be looking for a clogged or broken pipe. But i do not lnow anything about your plumbing as i have
never worked on your floorplan.
Does it eventually drain down in the shower after time. Or does it backup and stay backed up??
Snake camera time??
Jon Roche
75 palm beach
St. Cloud, MN
> Other question.
> Does the shower drain ok? Is it onlt the sink? If you pour water into
> showe does it go into sink??
> You might snake from the shower as it leads to your gray tank on your Royal
> Jon Roche
> 75 palm beach
> St. Cloud, MN
> have never worked on your floorplan.
> Snake camera time??
Hi Jon, it drains from the shower, doesn't take long just a few gurgles and drains down, maybe 20 seconds or so.
Mike
> Other question.
> Does the shower drain ok? Is it onlt the sink? If you pour water into showe does it go into sink??
If I pour water down the shower drain sufficient to create the back up it does drain. The water does not back up high enough to reach the sink, the
shower drain is much lower than the sink, in order to allow sufficient water to potentially reach the sink I assume the water would overflow out of
the shower enclosure and onto the coach floor.
Hope this makes sense.,
Mike
> > Other question.
> > Jon Roche
> > 75 palm beach
> > St. Cloud, MN
> Jim Kanomata
> jimk
> 1-800-752-7502
Hi Jim, sorry but there wasn't a message, just what's quoted above?
Mike
When you say "pour water down the shower drain sufficient to create the
back up", how much water is that? If it's less than 25-30 gallons (the
gray water tank capacity), the tank's not empty
and you've found your problem.
> > Other question.
of
> Mike
Is it possible that where the coach is, when the water is backing up is not level? In my rear bath royale, the tub backed up once. The grey tank
which is separate was near full, but I was also out of level with the back end a bit higher than the front. as soon as I aired the bags down a bit the
issue was resolved. There may not be much if any "run" in the drains if your shower drain is in the middle of the coach and your trying to send
water lower to the rearward grey tank.
Mid Michigan
Does the gray tank have a clogged atmospheric vent? If air can’t get out, new water can’t get in too easily.
>> Snake camera time??
> Regards,
> Mike
Take a snake at the shower as it will lead to the tank.
On Sun, Jan 21, 2018 at 7:35 PM, Dave Stragand <
> >> Snake camera time??
> > Regards,
> > Mike
Thanks again,
Ken... just a few gallons is all it takes to begin creeping into the shower, certainly less than the tank capacity.
If I "think" I have emptied the tank and it's not really empty this could be a/the reason.
I have filled the new water tank to approximately 50% capacity and drained it, water appeared to have good flow, I did this in the fall.
Perhaps it's time to snake the drains again in an attempt to address this issue.
77 Royale... the coach is on a flat concrete floor in my shop, however, the rear could probably be raised a bit as it does look a little low.
Dave... good question, I have added another vent from the main drain to an existing vent which I believe to be the black tank vent. I don't believe
there is a direct vent from the grey tank to the atmosphere... should there be a dedicated vent from the grey tank to the atmosphere?
Thanks for the input,
Mike
My guess is tank venting as well.
The water displaces the air in the tank, if the air can't escape the water can't get in.
Most tanks have at least one vent straight to atmosphere through the roof. Not sure of the grey setup on your coach though as I don't have a grey
tank!
Justin Brady
http://www.thegmcrv.com/
1976 Palm Beach 455
An easy test might be to open the gray tank dump valve -- allowing water/air out -- then try draining the sink.
Sent: Mon 1/22/2018 7:46 PM
Subject: Re: [GMCnet] Need plumbing advice, please?
tank!
Justin Brady
1976 Palm Beach 455
Justin, et al,
I don't see how venting can possibly be the problem. To run into the
shower pan, there MUST be liquid up to that level. H20 being a bit heavier
than air, even if the tank had no vent (which it apparently now has two of,
the original and the newly added one), the water would STILL go to the
bottom of the tank, not up into the shower. Admittedly increased pressure
in the tank MIGHT force a little bit, maybe a cup full, of water out of the
P-trap, but no more.
> can't get in.
> tank!
> Justin Brady
> 1976 Palm Beach 455
Most of the Royale GMC'S I have worked on with two tanks, use the kitchen
sink draining into the Greywater tank, and the lavatory sink, shower, and
toilet draining into the blackwater tank. The two tanks have separate drain
valves, whose drain pipes join downstream from the valve. Without some
errors in plumbing, I don't see how water poured into the kitchen sink
would wind up in the shower drain, which dumps directly into the black tank
after the p or j trap.
> Justin, et al,
> Ken H.
> water
> > can't get in.
> roof.
> > tank!
> > Justin Brady
> > 1976 Palm Beach 455
