Need parts from Parts Coach
Gary W. Mills
689
1
I need a few small parts from a parts coach. Would anyone have a front
speaker cover? I also need the neutral start switch at the bottom of the
steering column. I could use the L P Sending unit from a tank. I also
need a couple of bezels.  One for the water pump switch that is behind
the cooking range on a 1974 GMC outfitted coach.  Also the bezel for for
the hook that stick down form the ceiling for the bunk bed.
Any help is greatly appreciated.
Gary W. Mills
Livonia, MI
. ___________
./_][__][] []| 1974 GMC M/H
.*O-------OO-* Painted Desert
Gary,
Should you not locate the parts you need give me a call as I know we should
have them, but it would be more than what you can get from friends.
> steering column. I could use the L P Sending unit from a tank. I also need
> a couple of bezels. One for the water pump switch that is behind the
> cooking range on a 1974 GMC outfitted coach. Also the bezel for for the
> Gary W. Mills
> Livonia, MI
> . ___________
http://www.appliedgmc.com
