Need help with cabin heat ASAP (solved for now)
john r. lebetski
4,659
2
I thought he was referring to the dual Max AC duct as he has a 76. The recirc door on 77-78 would be sucking not a source of cold draft. Not sure of
the rec door location on 76 but might be more pass side.
John Lebetski
Woodstock, IL
I kinda think I'm experiencing the same thing. Is there a write up or photo power point on how to bypass this? Was hoping to place a inkine gate valve
to use for heating in the winter but block off hot water from core for air conditioning in thr summer?
> of the rec door location on 76 but might be more pass side.
Nope, not Dual Max AC, just a vent opening. I wonder if recirc valve or door is stuck open and I'm getting a blow by from the fan going in the
direction opposite to what was intended. Plan on sticking a flashlight in both directions today to explore it.
Vadim Jitkov
'76 Glenbrook 26'
Pullman, WA
