Ken,
I opened a can of worms for myself when I took a look at someone's coach after the GMCMI. There was too much play in the passenger rearmost wheel,
and that lead to discovering a loose bearing cup, broken brake shoes, an out of round drum on it's last legs, etc.
Trying to put it back together, I'm trying to locate seals that pass the 1/4" test and after hitting several auto parts stores and opening a dozen or
more boxes from several different brands, found that none of them passed, or were even that close. From the drawing in the manual it appears as you
say, that there's no way the metal could contact the bearing. So where did the 1/4" test come from? Does it matter?
Richard V.
> John,
> IIRC, you're thinking of the front wheel bearing seal. From the drawing I
> posted, it appears virtually impossible for the metal to touch the
> bearing. But the rubber is separated from it only by about the distance
> the seal should be left proud of the hub.
> https://drive.google.com/file/d/0B3XquSIYjDleenNDM1BHQlNHa1E/
> view?usp=sharing
> Ken H.
'77 Birchaven TZE...777
Richard V.
> John,
> view?usp=sharing
> Ken H.
