Mystery Electronics
gary j zingle
326
"If you just need the bulb, get a #74 bulb at your
local auto parts store. If the socket is missing or
broken, you can replace it with a bulb/socket
assembly used in some Audi instrument panels
- - part number 431 919 040 ( or 2721 MF8 ). Let
me know if you have trouble finding one."
Thanks Peter. I am sure that now that I have the
part numbers I should be able to find them locally.
I think what you are looking at is the "Low Fuel Lite
Unit/Switch". The book said the wire colors are:
white, black, pink w/dbl black stripe & lite green.
This is the circuit that determines when to turn on
the Low Fuel Lite. What you see is normal as is
& is not attached to anything.
Thanks Duane. My low fuel warning lite works fine.
Wouldn't have worried except for the bulb in the silly
thing.
Regards
Gary Zingle
1973 GMC 26 foot
