Sorry that URL didn't work..........not enough w's use this one, it's
more better: www.gmcmhphotos.com/photos/455-serpentin-e-jwid/p65051-
slide071.html
http://ww.gmcmhphotos.com/photos/455-serpentine-jwid/p65051-slide071.html
consider this modification to be a week end project, once you have all the
Components
1. Remove fan shroud, fan/fan clutch, water pump and crank shaft v-belt
pulley, all V-belts including A/C.
2. Remove power steering pump and all power steering brackets.
3. Go to Auto zone or others and rent the power steering pulley
remove/install kit.
4. Drill a 1/2" hole in the bracket power steering for the Idler pulley.
5. Reinstall power steering pump bracket with new pump, pulley and new
Idler pulley
6. Install new alternator pulley.
7. Install Modified crank and water pump pulley.
8. Confirm all pulley are in line with strait edge (Power steering and
alternator must will be most difficult to align)
9. install 6 rib X 57.5" serpentine belt.
10. Tighten Serpentine belt with alternator take-up.
11. Start engine and confirm alignment and tension.
12. Reinstall and tension AC V-belt.
Regards,
Tom Pryor
4188 Limerick Dr
Lake Wales, Fl 33859
Cell 248 470 9186
Living on a waterfront is not a matter of life or death. Its more
important than that.
slide071.html
Components
remove/install kit.
Idler pulley
Regards,
Tom Pryor
4188 Limerick Dr
Cell 248 470 9186
