> > Cinnabar did one thing for the furnace. They installed a heavy gauge plate
> > across the back, since the furnace can not be installed flush with the
> > outside wall as required by suburban installtion directions.
And then Arch wrote:.
> The only thing that might be different from a
> standard installation is that I jacked the back end up 1/2 inch. I cant
> believe
> that it cant run when it is that little out of level!
So I add the following:
Now my experience with another Suburban appliance, there 6 gallon propane fired
water heater, makes me believe that that at least the the water heater can be
mounted off level and work just fine. I haven't seen the furnace exhaust so my
water heater experience may not be relevant. But when I installed it a few years
back the Suburban instructions directed that the tank cabinet be mounted flush
with the outside wall as apparently the furnace directions call for. Anyway,
because of the GMC's curved sides mounting the water heater flat on the floor and
against the outside wall would leave about a 1" gap at the bottom between the
water heater's cabinet and the wall. But when I made some wedge shims to raise
the rear of the cabinet up off the floor about 1" the face of the cabinet aligned
nicely with the curved wall. I called and talked with a Suburban tech. rep at the
factory and asked what he thought about my tilting the the heater up by this
amount. While he wouldn't deviate from the Suburban printed directions (makes
sense given corporate liability in matters like these) he didn't disagree with me
either that the coach didn't have to be perfectly level either for the propane
burner to work and the exhaust gases to vent to the outside. In fact the
operating instructions don't call for the coach to be leveled before igniting the
burner. Now I wouldn't take this to the extreme and say the unit would work
properly if turned on its end either. At least in my case after considering what
actually happens in a non-perfect world of RVing and camping in unlevel
situations, I concluded that small deviations from the printed instrcutions should
work out OK. Of course this was just my experience and there's no gaurtentee
anyone else would have the same. I just thought I would share them with the group
for whatever they may be worth.
Phil Stewart
'76 Transmode, TN
> believe
Phil Stewart
'76 Transmode, TN
