my EFI Air cleaner
Keith V
3,582
376
83
I finally, after way too much analysis brooding and reflection figured out a half decent way to mount a remote air cleaner.
My criteria was:
1. It had to be a real air cleaner, not a oiled washable one that in reality never gets washed or oiled
2. It had to be serviceable, changing the filter should not require disassembling anything or suffering too much
3. it must draw in clean fresh cool air
4. The filter must be readily available
I feel this install met all the above, #3 isn't optimal as the inlet is pointing down, but it's off to the side of the radiator and should be clean. I
could possibly add ducting of I was so inclined
It uses a Wix 46573 filter out of a 2001 to 2020 Duramax. It has 190 square inches of surface area vs 110 for the stock filter.
This is the outside diameter NOT filter area.
Maybe Jim K can determine the actual filter area.
I used the Spectre hat and their 4" ducting, it worked out well. the jeep hat seems too small and restrictive for my comfort
Here is the bracket. This relocates the air tank closer to the fender allowing room for the filter
http://www.gmcmhphotos.com/photos/data/7303/medium/20210508_105740.jpg
here is how the air tank and filter mount to the bracket
http://www.gmcmhphotos.com/photos/data/7303/20210508_125320.jpg
here they are mounted in the coach
http://www.gmcmhphotos.com/photos/data/7303/20210508_133152.jpg
Here they are from the hood side. the front cover comes off and the filter is 'easily' replaceable
http://www.gmcmhphotos.com/photos/data/7303/20210508_133219.jpg
Here is the hat
http://www.gmcmhphotos.com/photos/data/7303/20210418_195216.jpg
Keith Vasilakes
Mounds View. MN
75 ex Royale GMC
ask me about MicroLevel
Cell, 763-732-3419
My427v8
Take a look at the inlet diameter of the OEM snorkle air filter housing. It
is somewhere around 3" in diameter. So with that knowledge firmly within
your grasp, 4" exhaust tubing should be way more than adequate. But, the
"AMERICAN WAY" is always that bigger is better than smaller. But not always
necessary. Just my take on it.
> My criteria was:
> clean. I
> Here is the hat
> Keith Vasilakes
> Mounds View. MN
> 75 ex Royale GMC
> Cell, 763-732-3419
> My427v8
Interesting approach to get more air to your induction system. Nicely done.
I am curious as to the make and model that you used to find your "Spectre hat and their 4" ducting"?
Richard
SE Michigan
www.PalmBeachGMC.com
James,
Upload some pics of the air intake off The Pig.
Sully
Bellevue wa.
> you should of made 2. now I have to make my own!
> Jon Roche
> 75 palm beach
> EBL EFI, manny headers, Micro Level, rebuilt most of coach now.
> St. Cloud, MN
> http://lqqkatjon.blogspot.com/
Jon,
well now you know how to do it!
I moved the air tank over exactly that the right mounting bolts lined up with the left bracket holes. The air cleaner was welded insitu and i have zero measurements. But it was shoved uo against the frame as much as possible
RJW, the spectre hat and hose are easily found.
Here is the hat on Amazon
https://www.amazon.com/Spectre-Performance-Polished-Profile-Single/dp/B004AJ6GIC/ref=mp_s_a_1_9?dchild=1&keywords=carburetor+hat&qid=1620747545&sr=8-9
James, they make bigger filters! This was basically the best compromise I almost made my own housing
Sent: Tuesday, May 11, 2021 8:51:54 AM
Subject: [GMCnet] Re: my EFI Air cleaner
Jon Roche
75 palm beach
St. Cloud, MN
