Thanks for the comments. I read all the comments again as I finally finished another project so I can get back on the RV.
Part of my problem I assume is the muffler I have installed. I have one muffler that is slightly low and goes across the the bottom. My trip last Nov. we found the back of the RV was warmer than the rest of the RV.
I have never been able to keep the Generator running when driving. After about an hour on the road it quits. When I park the generator will not run for a while. Once everything cools off the generator runs fine. My assumption is the fuel has gotten to warm. I’ve replaced the fuel pump and filter set up on the generator and that did not change anything. I can go out start the generator and it will run for hours with no problem.
I plan to make several trips with the RV do not want to have to use the interstates so that I do not have to go thru a town. It is generally only in town stop and go traffic that I vapor lock or when I stop for gas. Once on the road and good airflow under the RV the vapor lock goes away.
I will change to electric fuel pumps. One pump from each tank. It has been 10 years since I replaced the fuel line so I’ll change the fuel lines and use a T with check valves as Ken suggested. I’ll add installation around the fuel lines and paint the bottom of the tank with some sort of paint that also will insulate the tank some. Oh yea I will wrap the headers and the muffler with insulation.
What muffler should I use.
Art
> If you have old hose on the input of the pumps it can collapse under vacuum and shut off the flow. Higher vacuum causes fuel fumes, which only work in
> the intake manifold. Those pumps won't pump fumes fast enough. Haven't checked my fuel pressure at the carb when it happens, but there could be
> pressure with no liquid fuel. If the mech pump gets air it should still prime itself if fuel is available to it. I have power fall-off problem like
> vapor lock and I'm sure old hose is collapsing, unless it's plugged pickup screens. Either way, gotta drop the tanks to figure it out...already did
> everything else except refrigerate the ignition amplifier.
> Terry Kelpien
> ASE Master Technician
> 73 Glacier 260
> Smithfield, Va.
Art
> Terry Kelpien
> 73 Glacier 260
> Smithfield, Va.
