Movies on CD
al chernoff
737
>Now Emery, just because you live in NM, you don't have to stick up for al.
>gene
>I can use all the help I can get...
al
>Ms Meineken:
>You are looking for DVD enabled CD drive in your port-a-puppy..
>I use IBM Think-pad that came with option installed - very nice,
>plasma screen requires a fairly direct line of sight.. It makes nice
>choice for motorhome as you can catch up on any work if it rains a
>lot, but we can cut over to CD DVD for after dinner kids videos or
>something fun for Mrs. Dexter and I later..
>Interestingly, you want a fairly good wizard with right instruments
>to check around the plug sockets to get a fairly stable power
>source.. Variation in the power source (frequency weirdness) will
>dramatically shorten the life of the port-a-puppy battery..
Sorry you IBM folks have so many problems playing DVDs. My Mac
portable does a complete DVD without problems and the batteries are
still ready to go for another hour or so... ( I know I am starting it
again)..but I had to.
al
For most of us,if a seminar was on cd we could watch if it was in ".mpg"
format. This format will play on the Windows Media Player already installed
with Windows. This is different than dvd and nothing extra to buy or
install.
>From the Desk of:
Terry Doukas the wannabe
http://tadoukas.homepage.com
tadoukas
To: "gmcmotorhome"
Sent: Monday, July 03, 2000 9:41 PM
Subject: GMC: Movies on CD
> Ms Meineken:
> I use IBM Think-pad that came with option installed - very nice, plasma
screen requires a fairly direct line of sight.. It makes nice choice for
motorhome as you can catch up on any work if it rains a lot, but we can cut
over to CD DVD for after dinner kids videos or something fun for Mrs. Dexter
and I later..
> Interestingly, you want a fairly good wizard with right instruments to
check around the plug sockets to get a fairly stable power source..
Variation in the power source (frequency weirdness) will dramatically
> It is on a scale with Onan repairs in the event you spud the portable
battery.. On the IBM, the system uses battery all the time and kinda charges
as you go.. There is no inverter as such to convert DC power for direct CPU
use - even though it is plugged in, it is still using batteries..
> This has the downside that your system will work fine for while outside
the basic power company frequency specs - but - it will damage your portable
computers' battery such that you begin to see weird power curves.. Mine, for
example, will happy cook along for a couple of hours on the battery, then
read 35% juice, then about 4 minutes later - read about 4% and start to
stroke out..
> Some folks I know, who are in the know, say that they see Portable
batteries come back all the time that have been damaged on generators,
cottage, ship and dash-board power..
> But, if you can fine a cabin plug that is close to frequency spec for
household AC.. you should be ok if you work off the first charge without
plugging in - then plug into cabin ac - charge while you work - then pull it
out of the wall and let it cycle down again when it tops up..
> This assumes you are 'close to Power Company AC frequencies' - if you are
really out of frequency you'll spud the battery in the computer whatever you
do.. I think you can buy a relatively cheap plug tester from radio shack to
keep up on events behind the fuse panel. Surge protectors and fused plug
stiks are not what we are talking about here - they are not sensitive enough
to changes in power feed to be of any real security..
> On the upside, if you do get a serious blow out - it is likely that you
will ONLY cook your port-a-puppy's battery and not all the other expensive
bits under the keypad.. Which is actually a nice choice on their engineers
part really..
> Depending you your portable, you should get enough DVD battery juice for,
say, Kelly's Hero's or Night of the Generals.. But will probably have to
work on charge down - plug-in - charge up - charge down cycle if you go for
the I Claudius box set from our good friends at PBS..
> DVD consumes power pretty flat, which is actually really good for your
portable's battery - if the juice is right.. Gives it a nice deep cycle a
couple of times in a row and provides a really long flat charge cycle while
the DVD is playing which mine seems to like immensely..
> There are several schools of thought on all this, 'natch, but that's what
I'm seeing and hearing at my end.. Computer batterys, portables in general,
are much less standardized than the big box you have in the office..
> your pal
> J Dexter
> ps: I'm on digest, I was wondering if there were any leads on wider front
rims question? - To revisit - I hope I was clear, I'm not talking about
messing with rear rim specs at all - bags won't take it and dangerous given
rear axle weight spec, just trying to get wider set of fronts to square the
foot print without going to Axle replacement.. I want to get this rim and
tire business done before sanity again regains it's hold on family budget
sub-committee..
Ms Meineken:
I use IBM Think-pad that came with option installed - very nice, plasma screen requires a fairly direct line of sight.. It makes nice choice for motorhome as you can catch up on any work if it rains a lot, but we can cut over to CD DVD for after dinner kids videos or something fun for Mrs. Dexter and I later..
Interestingly, you want a fairly good wizard with right instruments to check around the plug sockets to get a fairly stable power source.. Variation in the power source (frequency weirdness) will dramatically shorten the life of the port-a-puppy battery..
It is on a scale with Onan repairs in the event you spud the portable battery.. On the IBM, the system uses battery all the time and kinda charges as you go.. There is no inverter as such to convert DC power for direct CPU use - even though it is plugged in, it is still using batteries..
This has the downside that your system will work fine for while outside the basic power company frequency specs - but - it will damage your portable computers' battery such that you begin to see weird power curves.. Mine, for example, will happy cook along for a couple of hours on the battery, then read 35% juice, then about 4 minutes later - read about 4% and start to stroke out..
Some folks I know, who are in the know, say that they see Portable batteries come back all the time that have been damaged on generators, cottage, ship and dash-board power..
But, if you can fine a cabin plug that is close to frequency spec for household AC.. you should be ok if you work off the first charge without plugging in - then plug into cabin ac - charge while you work - then pull it out of the wall and let it cycle down again when it tops up..
This assumes you are 'close to Power Company AC frequencies' - if you are really out of frequency you'll spud the battery in the computer whatever you do.. I think you can buy a relatively cheap plug tester from radio shack to keep up on events behind the fuse panel. Surge protectors and fused plug stiks are not what we are talking about here - they are not sensitive enough to changes in power feed to be of any real security..
On the upside, if you do get a serious blow out - it is likely that you will ONLY cook your port-a-puppy's battery and not all the other expensive bits under the keypad.. Which is actually a nice choice on their engineers part really..
Depending you your portable, you should get enough DVD battery juice for, say, Kelly's Hero's or Night of the Generals.. But will probably have to work on charge down - plug-in - charge up - charge down cycle if you go for the I Claudius box set from our good friends at PBS..
DVD consumes power pretty flat, which is actually really good for your portable's battery - if the juice is right.. Gives it a nice deep cycle a couple of times in a row and provides a really long flat charge cycle while the DVD is playing which mine seems to like immensely..
There are several schools of thought on all this, 'natch, but that's what I'm seeing and hearing at my end.. Computer batterys, portables in general, are much less standardized than the big box you have in the office..
your pal
J Dexter
ps: I'm on digest, I was wondering if there were any leads on wider front rims question? - To revisit - I hope I was clear, I'm not talking about messing with rear rim specs at all - bags won't take it and dangerous given rear axle weight spec, just trying to get wider set of fronts to square the foot print without going to Axle replacement.. I want to get this rim and tire business done before sanity again regains it's hold on family budget sub-committee..
Salutations:
Actually, the point I was making was that dirty power is hard on lap-top batteries if you leave them on plugged in after they are 100% charge.. (which, if I understand my contacts correctly - is the heart of the pwob) ..
Regarding MAC's, actually - the whole new machine is an almost a perfect multi-media machine and was designed as such. If all I were doing was playing vids and surfing, I'd be looking there myself.. Tell me, how many hours exactly can you get out of a battery running DVD CD on Mac Port-a-puppy?
your pal
J Dexter
>Salutations:
>your pal
>J Dexter
The new Mac portabel gets 5 Hrs plus on a battery. It does great on
almost anything, including looking like a PC with connectixs virtual
PC.
Hey Al. If the MAC is so good why do they spend money on a program and
styling to make it look like a PC. :0 Gene told me to send
that. Darren
> >Salutations:
> >your pal
> >J Dexter
> PC.
Darren Paget
76 Experimental
Another Fab Day
http://www.TZEplus.com
>that. Darren
>Becasue some people cant do without their pc.... we can do both, so
>why worry about one or the other.
al
>that. Darren
I'll answer this one. The program Al mentioned Virtual PC allows one
to run all Windows 95, 98 and 2000 programs on a Mac. What software
is available to run all Mac programs on a PC? I use a Power PC Mac
G3 but I also use a HP notebook with Windows.
Emery Stora
77 Kingsley
Santa Fe, NM
gene
>>that. Darren
>Emery Stora
>77 Kingsley
>Santa Fe, NM
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
>>gene
>al
And there are Mac users in CA too. I'd bet a poll would show at least 10%
of GMCnetters use Macs.
Dave (advisor/navigator) & Dege (ALL else), '76 Royale, Santa Barbara, CA
>>a program and styling to make it look like a PC. :0
>>Gene told me to send that. Darren
>allows one to run all Windows 95, 98 and 2000 programs on
>a Mac. What software is available to run all Mac programs
>on a PC? I use a Power PC Mac G3 but I also use a HP
>Emery Stora
>77 Kingsley
>Santa Fe, NM
You ask "what software is available to run all Mac programs
on a PC."
I would ask Who would you sell the software to? you would
need to find PC owners that want to run Mac software.
Alan Bredbury
Clinton, Ct.
1974 GMC 26' Classic Motorhome
http://www.finesttool.com/index.html/special.htm
Do You Yahoo!?
Send instant messages & get email alerts with Yahoo! Messenger.
http://im.yahoo.com/
>on a PC."
>Alan Bredbury
>Clinton, Ct.
Alan - I am going to drop this thread because it serves no purpose.
I will only say that you are right. Those people and business that
want to do all the things that Mac software will do don't even try to
use their PCs for those purposes -- they just buy a Mac.
Emery Stora
77 Kingsley
Santa Fe, NM
Gotta concur. Nothing like a good ole MAC G3 PowerBook to run DVDs, CDs,
websites, email, GPS, engine analyzer, multimeter readings records, Street
Atlas . . . (and as was said in the "King and I") etcetera, etcerera,
etcetera. Plug it in; Power it up; Play it. A capable tool in a
roadwarrior's kit.
Fritz Washburn
'77 Kingsley
Twin Cities
> From: J Dexter
> Organization: Cybermation
> Reply-To: gmcmotorhome
> Date: Tue, 04 Jul 2000 15:31:22 -0400
> To: gmcmotorhome
> Mac Port-a-puppy?
At least one 2 1/2+ hour movie's worth. More if you properly configure
the operating system by stepping down the processor speed in the Energy
Saver control panel. Apple says "you can watch a DVD feature movie (namely,
Austin Powers) twice on a single battery's power." Can, not would want to.
Even more with a new PowerBook (Bronze). About another half hour.
Fritz Washburn
> From: Darren Paget
> Date: Tue, 04 Jul 2000 20:45:22 -0600
> To: gmcmotorhome
> Subject: Re: GMC: Movies on CD
> that. Darren
So we can quick fire it up when one of you Windoze guys comes around to keep
ya from gettin' jealous.
Couldn't resist. That's all from me.
Fritz
