Ken,
This might be a better shortcut to the picture album. Previously posted link took you to only one picture and could not see the others.
http://www.gmcmhphotos.com/photos/member-galleries/p26079-motorcycle-carrier.html
JR Wright
> OK, I found a few pictures here of the home made carrier that I built.
> Start here and page forward:
http://www.gmcmhphotos.com/photos/data/500/medium/DSCN1327c.JPG
> It is made out of scrap 2" OD box tubing and a tray that I made out of a piece of scrap flat metal probably 1/32" thick and 8' X 12". I had a local
> fab shop bend it in a U shape to make the tray. It took them less than 5 minutes and they charged me $10.00 (IIRC). That included the cost of the
> scrap steel. The pivot is a simple door hinge mounted to the receiver tube and tray. One thing instead of using a 5/8" receiver pin to mount the
> drawbar part into the standard 2" receiver, I drilled and tapped 5/8" threads into the drawbar and bolt it in place using 5/8" bolts. I also made a
> second set of holes in the drawbar to allow the use of a standard 5/8" pin. At the time I figured it would keep it from rocking with the bolts.
> Well, I have used it both with the bolts and with the pin. I did not see any difference.
> The one thing I have discovered over the years is that all receiver hitches are not make the same. The commercial manufacture's and Blaine Merrell
> make the center tube out of 2" ID steel tube. Notice I said ID. This stuff is expensive and hard to find. You have to buy it in long lengths and
> then have enough to make 6 or 8 hitches. The problem happens is when people buy say 2.25" OD with a 1/8" wall box tube instead. The outside is
> correct but the inside in not necessarily 2". Some are smaller and some are bigger. Also most of it is welded and the weld thicknesses inside are
> not important when it is manufactured. This is a real problem when trying to insert a 2" drawbar. I loaned my carrier to a GMC guy one time who
> called me and said my draw bar was too big and that he was going ti grind it down for me. I stopped him in time and said that drawbar had been used
> in at least 10 different vehicles with no problem. I told him he needed to fix his receiver ID. I have also seen one where the ID was too big so and
> the long drawbar drooped down an rattled occasionally.
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
