Check the motor mounts! If you replace the Radiator leave off the oil
cooler at the bottom. Just have it removed. Add auxiliary oil cooler,
transmission cooler. If you don't do this then change the hoses at a
minimum and re route them away from the exhaust manifold on the right
side. Clean the recovery tank and replace the lines. Be careful. This
thing will crack easily. Be sure to add a screen mesh cover about 1/4
size squares to the bottom to protect the two coolers. If you are
interested in more air to the carburetor you should consider "RAM AIR"
this can be accomplished by adding air scoop at the grill area and
connecting it to the air intake of the carburetor's air cleaner. Change
the air cleaner out to a K and N (reusable). While all this is undone,
check to see if your battery cable has been damaged or the plastic
protection covering needs to be put on or replaced. This cable runs
across the front of your radiator at the bottom. If you take the
radiator out you will need to remove the grill. VERY CAREFULLY. Then
make a piece to attach to each side of the two fenders to assist in
holding the grill stable. This is a weak place on the front of the
GMC. If you take the radiator out it comes straight down not too much
trouble, I used a small floor jack. The coach must be on JACK STANDS
about 24 inches up. Check the battery compartment in the front. If you
are going to change out this arrangement make the parts up and have them
ready to install. Mine are made of 1/4 inch thick steel. They can be
dropped from the bottom. The bolts to secure the battery are also
welded to the sides instead of moveable. The top is moveable and it is
much easier. Don't forget to put in holes for drips, either a wooden
floor or fiberglass the entire thing with the resin. I think that is
all for this area. Chuck
