Finally got my ping problem narrowed
down. I tried new hd springs on the
mechanical advance. No difference...
still pings even at 8 degrees. Finally,
out of desperation I tried unhooking the
vacuum adv and plugging it off as I test
drove it. It has a 10 stamped in it so
it looks like the right advance
mechanism. Lost a bit of power but that
resolved the ping issue instantly. Man
thats nice not hearing those anymore.
Hate to see what my gas milage would be
like this way! I feel pretty confident
now that the adjustable vacuum advance
will do the trick once it comes in later
today.
FYI the spring/weight kit also mentioned
that if you can't stop the ping by using
the springs supplied to look at a GM p/n
vacuum restrictor. It gives 0 vacuum
advance under load. I haven't heard of
these but assume it works like a delay
circuit or similar to a bucket of water
(ie. takes awhile to fill up but empties
out quickly). That way it would still
gives full vacuum advance once you are
up to cruising speed for good gas milage
but stops the pings.
Nate '75GB (finally on the right track)
Omaha
today.
Omaha
