You'd better be careful! When he sees you sitting in the coach salivating
over the manuals, you ain't a gonna make no swift deal! But it sure is fun,
isn't it?
Best regards,
Travis
- -----Original Message-----
To: gmcmotorhome
Date: Tuesday, August 24, 1999 9:48 PM
Subject: GMC: More on the '76 PB Purchase
>Okay guys thanks for the advice, decide to pursue the less expensive GMC.
I
>went to talk and deal today but the owner had already left for the day.
I
>decided to spend some time with the GMC anyway, one of his employees gave
me
>the keys. I spent about an hour checking things over, reading the manuals
>and taking some pictures. I posted some of the interior pics at:
>http://members.aol.com/gmcmotor/gmcin.html
>A couple things I noticed and had questions about:
>1.) The air bags must leak. When in auto the compressor runs for a while
and
>stops then starts cycling; 30 seconds off 10 seconds approx. It's obvious
it
>needs a fix what should I expect in terms of cost.
>2.) I let the faucet run for a couple of minutes until it stopped, I then
>switched on the pump, no more water came. I'm pretty sure there was water
>left in the tank. I couldn't hear the pump either. I'll have the guy
repair
>this.
>3.) Spent some more time looking at the engine. Looks good from the top
but
>I'm concerned about all the oil on the oil pan. There doesn't seem to be
any
>oil leaking onto the ground but the oil pan is pretty well covered.
>4.) How does the toiled work? (chemical) does it function OK and how does
one
>operate it.
>Other nits, the headliner in the cab bows down slightly like it's fallen
away
>from the ceiling, the bottom of the entry door is slightly damaged, the
>bathroom has a small gap around the top near the rear, look like this can
be
>adjusted.
>Also a friend looked up the "book" values at the local credit union today,
I
>think for a '76 it was 9-10K wholesale and 12-13K retail, seems like many
are
>going for more.
>I'll probably try to get in contact with a mechanic (if I can find one) to
do
>an engine inspection before making an offer.
>Chris Taylor
>GMC Wanna Be
>Rochester, MN
isn't it?
Best regards,
Travis
To: gmcmotorhome
I
I
me
and
it
repair
>this.
but
any
one
>operate it.
away
be
>adjusted.
I
are
>going for more.
do
>Chris Taylor
>GMC Wanna Be
>Rochester, MN
