Never seen ANY broken CV joint bolts, but I have seen a whole bunch of them
come loose and fall out on the road, PARTICULARLY on the drivers side of
the coach.
If I encounter a really "grungy" coach, I liberally clean that area
with Brake Kleen and chase the threads with a thread chaser tap. Then a
follow up spray with carb cleaner, followed by compressed air. Then, new
bolts and the special lock washers, with blue loctite. Torque to spec. (65
- 70) foot pounds. Makes me cringe to put that much torque on that little
bolt, but, they are supposed to be a one time use deal.
Salem, Or
On Wed, Aug 14, 2019, 8:06 AM Richard Denney via Gmclist <
> Johnny, I should have said the structure is loaded in shear, not tension.
> Therefore, there is no structural tension load on the bolts, in addition to
> their tightening tension. That’s why they can be tightened to near proof
> load.
> Engineers often state that bolts are loaded in shear when they mean that
> structures are loaded in shear. Any bolted connection that uses holes large
> enough not to be an interference fit carry their loads by clamping
> friction.
> I’m not opposed to Loctite by any means, though I do wonder how that
> changes the torque requirements. I am opposed to using Loctite as an excuse
> to avoid tightening them to spec, in the false notion that the bolts can’t
> take it. I’ve heard of many loosened drive axles, but I’ve never heard of
> broken bolts during or after torquing, if they were the proper
> high-strength bolts.
> Rick “the factory didn’t use Loctite” Denney
> On Wed, Aug 14, 2019 at 10:53 AM Johnny Bridges via Gmclist <
> > If the clamping tightness is such that the plate doesn't move relative to
> > the CV plate, the bolts are in tension. Should the two plates move, then
> > the bolts are in shear. I used blue LocTite on mine at 60 ft-lbs
> and
> > they haven't moved since I got the coach. I figured the thick locks were
> > there for a reason, and the Fastener Room at Coker's had a boxful so I
> > used them.
> > Foolish Carriage, 76 26' Eleganza(?) with beaucoup mods and add - ons.
> > Braselton, Ga.
> > I forgive them all, save those who hurt the dogs. They must answer to me
> > in hell
> '73 X-Glacier 230 "Jaws"
> Northern Virginia
> Offlist email: rick at rickdenney dot com
