More battery discussion
ghickey
Member
Jun 12, 2019
73
8
8
I was following the recent discussion about the batteries with a
particular interest. I have now completely replaced the line from the
engine batteries to the house batteries. The line was definitely the
original line installed and the line had not faired very well in the
past 45 years as the line was very corroded and all the insulation was
chipping off. So I am glad that I have the line replaced now.
I also want to thank those that discussed the dangers of charging two
12v batteries in parallel. When I picked up my RV last year it had two
dissimilar batteries for the house batteries. I had planned in all the
rewiring that I am doing to put both in parallel. On first thought it
seemed like a great plan, but I am glad to read the discussion about the
internal resistance of the batteries. Never would have thought about it
from that angle and quite possibly saved me a disaster.
The solenoids at each end of the line appear to be original also. I was
thinking about replacing them also, but then thought about my plans to
replace the battery isolator. I have been looking at replacing it with a
Victron Cyrix-ct or a Li-Bim isolation module (if anyone has any strong
opinions of either, I would love to hear them). In replacing the battery
isolator with current technology is there still any need for the
solenoids? I can not think of a reason but I figured I would ask here of
those of you that are much more knowledgeable about the GMC electrical
system.
One other question also. In the generator compartment above the solenoid
there is a device about 1.5 inches in diameter with two terminals on it.
It appears to me to be a fuse as it appears to be a short between the
terminals. Although I as am writing this I started to wonder if it is
actually a diode to allow current to flow back to the engine compartment
for boosting the current to the starter motor. Can some one identify
this device or confirm my latest suspicion?
Gerard Hickey / WTØF IRLP:3067/Echolink:529661
hickey DMR: 3102272
425-395-4554
> I
> terminals.
That is a 60a circuit breaker designed to protect the house electrical system.
If you get a Li BIM it will replace both the isolator and the front boost solenoid (you would still need the rear boost solenoid).
Jeremy
Jeremy Sanford
Sacramento, CA
1977 Kingsley
http://www.gmcmhphotos.com/photos/u42733-jsanford.html
Gerard,
The bakelite pucks are self resetting circuit breakers that are there to keep the #10SAE cable from setting fire to the coach if there is an issue.
They have by-pass contactors (solenoids) to allow the boost system to work in the later coaches when the house bank is in the rear.
I personally am extremely ambivalent about isolators and combiners and have no experience with the two you referenced. I am very fond of the idea of
isolated DC systems for lots of reasons.
> I was following the recent discussion about the batteries with a particular interest. I have now completely replaced the line from the engine
> batteries to the house batteries. The line was definitely the original line installed and the line had not faired very well in the past 45 years as
> the line was very corroded and all the insulation was chipping off. So I am glad that I have the line replaced now.
> I also want to thank those that discussed the dangers of charging two 12v batteries in parallel. When I picked up my RV last year it had two
> dissimilar batteries for the house batteries. I had planned in all the rewiring that I am doing to put both in parallel. On first thought it seemed
> like a great plan, but I am glad to read the discussion about the internal resistance of the batteries. Never would have thought about it from that
> The solenoids at each end of the line appear to be original also. I was thinking about replacing them also, but then thought about my plans to
> replace the battery isolator. I have been looking at replacing it with a Victron Cyrix-ct or a Li-Bim isolation module (if anyone has any strong
> opinions of either, I would love to hear them). In replacing the battery isolator with current technology is there still any need for the solenoids?
> I can not think of a reason but I figured I would ask here of those of you that are much more knowledgeable about the GMC electrical system.
> One other question also. In the generator compartment above the solenoid there is a device about 1.5 inches in diameter with two terminals on it.
> It appears to me to be a fuse as it appears to be a short between the terminals. Although I as am writing this I started to wonder if it is actually
> a diode to allow current to flow back to the engine compartment for boosting the current to the starter motor. Can some one identify this device or
> hickey DMR: 3102272
I installed a Li-BIM early this year, along with a LiFe-Po4 house battery in the rear . Have only been able to make a couple of trips since then but
so far am satisfied with it. Particularly like that it will limit the time the alternator will charge a depleted house battery, allowing time for the
alternator to cool. Also, when plugged in to shore power, it monitors the engine battery charge state and connects it to the PD-9260 charger.
The Li-BIM has replaced the Isolator, Power Contactor, and Combiner in front, & I left the OEM 60 amp Fuse and Bypass Contactor in back so the
original boost function is intact.
JWID, John S
John Shutzbaugh, Vacaville, CA, ncserv;
77 Eleganza, bought it new, can't blame PO; and
78 Buskirk stretch, "What were we thinking?"
As I read it the Li-BIM is a combiner tuned slightly differently. What I have a problem with is your removal of the front solenoid. The front and
rear solenoids have nothing to do with charging batteries (front or rear). Both solenoids remain open for 99+ % of their life and are only energized
and used when the boost switch on the dash is pressed. Someday you are going to want that emergency boost function to work to move a couple hundred
amps to start the coach.
> and rear solenoids have nothing to do with charging batteries (front or rear). Both solenoids remain open for 99+ % of their life and are only
> energized and used when the boost switch on the dash is pressed. Someday you are going to want that emergency boost function to work to move a
> couple hundred amps to start the coach.
The wire from the boost switch connects to one of the terminals on the LI-BIM so that it can replace the front solenoid and preserve the GMC original
boost function.
Jeremy Sanford
Sacramento, CA
1977 Kingsley
I might be reading this wrong and I'll go look again. I think you are mistaking a combining function for charging rather than boost function of
several hundred amps used for starting.
I will go look again. What is the maximum capacity of this item when combining?
Ken,
It is designed specifically to allow emergency boost operation. The old front solenoid power wire gets connected to the SIG post on the LiBIM225. The
specs for the contacts are 1600A for 30 seconds intermittent.
http://precisioncircuitsinc.com/wp-content/uploads/2019/10/00-10041-26x-Li-BIM-Rev1.pdf
Jeremy Sanford
Sacramento, CA
1977 Kingsley
Ok, from what I read, the maximum is 198 amps. Nothing is said what happens if you try to exceed this during engine starting. It should allow manual
combining to charge the opposite battery with no problem unless there is a dead short or something drawing more than 200 amps.
I still question it's ability to really start the engine under some conditions. I would leave the solenoid installed. Besides that, it makes a good
terminal block for all of those heavy cables.
I do not know if your rear solenoid question was answered. This rear item is just a relay with heavy contacts capable of a couple hundred amps. It's
purpose is to bypass the 50 or 60 amp automatic reset CB in the line from the rear battery(s) during boost starting.
I'm watching this with a bit of interest. In my uses however, the house batteries are only required to keep the icebox up during refueling and
hooking up at campsites. In eight years of GMCing I have overnighted twice without shore power, both in the winter. All the batteries have to do is
run the furnace, and I could have fired the genset both times if needed.
Linda qualifies for 2 new 12V batteries in her powered wheelchair every year. Deep cycle. That keeps me nicely supplied for the GMC house batteries. And for our collector cars. With cool temps. They can run our furnace for2 days. This set is 4 years old. Very strong output stile. But for just under $800 for the par. They should be. Our Coe pay is about $60. Makes for cheap batteries.
Bob Dunahugh
78 Royale since 2003.
4 COPO Yenkos
